Author Topic: How FSK modulation done using FPGA coded using FPGA?  (Read 917 times)
Offline aln
« on: February 17, 2010, 08:55:55 PM »
How FSK modulation done using FPGA coded using FPGA..help nman poh
Offline e.novacek
  • Pogi/Ganda Points: 62
  • The LionHeart
Re: How FSK modulation done using FPGA coded using FPGA?
« Reply #1 on: February 25, 2010, 10:53:43 PM »
This falls under the category of "Signal Processing Techniques for Communication Systems"
Your project is "excellent" indeed if your a student doing thesis-based related works, I suggests you to study "Algorithm's" .. and it is more meaningful, if you start working and mesmerizing "DSP" algorithms down to "Communication" algorithms.. The idea is to integrate this two.. I suggests also to explore "Matlab Software" to better comprehend "these" algorithms into practical applications..
There are available "Starter-Kits" from Alterra and Xilinx and it would be very helpful if you own one and work with it.
Take the gun. Leave the cannoli.
-Mario Puzo
