Author Topic: 2 Operating System problem. help naman mga master ng elab.  (Read 1509 times)
Offline ricnew2
  • Ther's no rebound.
« on: February 20, 2010, 11:00:59 PM »
mga sir/ma'am. panu ba to? etong pc ko 2 ang OS isang vista and windows 7.
bali unang nainstall yung vista next is windows 7.
tpos ni repormat ko yung sa vista wich is drive c.(windows 7 is drive e)
tpos install ko na uli yung vista sa drive c. after successful installation nawala na yung boot up choices.
pano ko kaya yun maibabalik, without reinstalling windows 7 nmn? thanks a lot po in advance.
Offline e.novacek
  • Pogi/Ganda Points: 62
  • The LionHeart
Re: 2 Operating System problem. help naman mga master ng elab.
« Reply #1 on: February 20, 2010, 11:22:44 PM »
I think, what you had done in the last which is installing windows vista in drive C automatically over rides any "boot loader path" or boot manager (e.g., bootsect.exe) other than its own.
My recommendation is try to boot from your installer and work with the "Repair" mode and then know how to use the "fdisk" and "fixmbr" .. this is a very crucial task especially if you don't have experience working with it..
Next time, I recommend you to use the "EasyBCD" which is a third-party tool dedicated for "boot-loader management" especially Windows..
Take the gun. Leave the cannoli.
-Mario Puzo
Offline cirkitbored!
  • Pogi/Ganda Points: 21
  • Somebody’s boring me — I think it’s me.
« Reply #2 on: February 21, 2010, 08:02:48 AM »
tama.. gamit ka na lang ng EasyBCD from neosmart.net/dl.php?id=1.
Meron pang isa Yong VistaBootPro (free version) kaso lang in-upgrade na nila to DualBootPro (license required) because of Win 7 release.
visit mo pa rin link:
http://www.vistabootpro.org/
tip from Windows Help (fragments...)
Multibooting requires separate partitions on your computer's hard disk for each operating system. If you're running one operating system, you can't run a program installed on another operating system. You'll need to install programs on each operating system that you want to use them in. You must restart your computer each time you want to switch to a different operating system.
You also need to install the oldest operating system first, which can be frustrating if you want to add an earlier operating system (for example, you're currently running Windows 7, but you want to add Windows Vista or Windows XP).
Warning
Installing an earlier version of Windows after a more recent version is already installed can render your system inoperable. This can happen because earlier versions of Windows do not recognize the startup files used in more recent versions of Windows and can overwrite them.
Ang hindi lumilingon sa pinanggalingan, mabilis makakarating sa paroroonan. :D
Ang taong mahilig mag-aral sa gabi, kinabukasan ay puyat. :D
Kung kaya ng iba, bakit tutulong ka pa!?! :D :D
Offline ricnew2
« Reply #3 on: February 21, 2010, 08:33:32 AM »
@e.novacek and  @cirkitbored! thanks po. bale nkuha p sa repair ng windows 7. ayun narestore
naman. salmat po sa mga idea. i'll keep in mind your sugestions. thanks.
pogi point sa inyong 2.
Offline aries_1621
« Reply #4 on: March 25, 2010, 08:32:35 PM »
Isn't it a waste of disk space to have two Windows OS installations. What can you do on Vista that you cannot do on Windows 7 or vice versa? It would make more sense if the other is a different OS. Say linux.
Offline kelvinblank
  • Pogi/Ganda Points: 4
« Reply #5 on: March 26, 2010, 05:07:22 PM »
i think applications issue lang to kaya 2 OS nya
Offline n0th1n6
« Reply #6 on: March 26, 2010, 05:35:41 PM »
You can also edit boot.ini so that the boot manager looks for the other OS on another partition. But since it is already fixed then congratulations to you.
Offline kelvinblank
« Reply #7 on: March 26, 2010, 05:37:15 PM »
sa msconfig ata mkkta mo yang boot.ini tama po ba?
Offline lordemtech
  • Pogi/Ganda Points: 17
  • "Life is how you make it"
« Reply #8 on: October 07, 2010, 05:22:24 PM »
tama!
"I am a slow walker, but i never walk back"
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #9 on: October 07, 2010, 08:28:52 PM »
I agree po parang waste of disk space na pag naka dual boot ang vista at win7. Ok lang pag xp at win7 or vista or linux. If vista at win7 naka dual boot, wala na pong boot.ini. As mentioned above, EasyBCD po would be very useful.
Opinion lang po, hindi po ako expert. :D
Offline !KuGZ$
« Reply #10 on: November 17, 2010, 06:57:01 PM »
You corrupted your MBR it's pretty common error if you r new to this.
Why not use VMware or VirtualBox? It's easy and no headaches.
CHFI CEH LPT ECSA BSIT
Offline lordemtech
« Reply #11 on: February 08, 2011, 07:12:27 AM »
reading mode...
Offline /
  • Pogi/Ganda Points: 317
« Reply #12 on: February 23, 2011, 12:42:12 AM »
late na ako ah EasyBCD din ang recommend ko to create boot loader..
Offline centOS
  • Pogi/Ganda Points: 45
  • screw the screw
« Reply #13 on: February 24, 2011, 08:17:07 AM »
^ oo nga late kana wag kana lang pumasok mag leave kana lang :D :D :D
Offline /
« Reply #14 on: February 24, 2011, 05:24:57 PM »
^nyahahaha gaga ka talaga cento cento.. ;D ;D ;D
Offline centOS
  • screw the screw
« Reply #15 on: February 26, 2011, 09:21:10 AM »
biglang nag linux tuloy si ts sis hunter ng dahil sayo :D :D :D
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
« Reply #16 on: February 26, 2011, 02:22:30 PM »
kaka reinstall ko lang ng PC.  Easy BCD din gamit ko.  Win7, vista, ubuntu.
