Author Topic: Help!!! Verify failed at address 0000h !  (Read 1813 times)
Offline engineer7@home
  • Pogi/Ganda Points: 13
  • Google Search--> Noel Rios Circuit Cellar
Re: Help!!! Verify failed at address 0000h !
« Reply #20 on: June 10, 2010, 11:11:00 PM »
1. Using your software for JDM PIC Programmer Paki erase yung PIC16F84
2. Check if the PIC is blank using the Software for JDM
If it cannot erase the PIC16F84, something is wrong with your VPP supervoltage,Usually 12V or 13V.
If it can erase the 16F84, and passed the Blank Check, Please read the code memory of the
16F84 and all memory locations should be 0xFF. This will test if your JDM PIC Programmer can reliably read the Program Memory of the 16F84.
You can also try another PIC16F84, maybe the PIC you have used is defective by electrical overstress or ESD.
I hope your JDM Programmer has worked before when you assembled it. If not, please check your circuit or the components you have used.
Love the Lord your God with all your heart & soul and with all your mind & strength.And love your neighbor as yourself.
The devil only comes to Kill,Steal & Destroy John 10:10
UKrobotics
Microcircuits gave me schizophrenia for Php2600/month in 1992
Offline Mayalin22
  • Pogi/Ganda Points: 400
« Reply #21 on: June 10, 2010, 11:17:46 PM »
hehe pa-OT nahihiwagaan lang ako  :D :D
Pindot at engineer7@home ... si Pidot at Manay ba kayo?  :o
