Author Topic: help po sa project na clap switch  (Read 2007 times)
Offline engineer7@home
  • Pogi/Ganda Points: 13
  • Google Search--> Noel Rios Circuit Cellar
Re: help po sa project na clap switch
« Reply #20 on: March 27, 2010, 09:52:22 PM »
According to the schematic, R7 and R6 form a voltage divider to have a voltage half the supply.  This is a bias for the 74HC14.  Maybe, you should adjust VR1 for the sensitivity of the clap switch so that there is no false triggering.
  Hope this helps.
Love the Lord your God with all your heart & soul and with all your mind & strength.And love your neighbor as yourself.
The devil only comes to Kill,Steal & Destroy John 10:10
UKrobotics
Microcircuits gave me schizophrenia for Php2600/month in 1992
Offline tough
Re: pwede ba to gamitin sa flourescent lamp?..
« Reply #21 on: June 20, 2010, 12:07:22 PM »
Pwede po ba gamitin tong circuit na to sa flourescent lamp?.. 220v AC ang source.. pwede po ba?
Offline purpledee
« Reply #22 on: June 22, 2010, 08:01:57 PM »
oo tama eto rin sana itatanong ko.. pwede bang mag turn-on ang flourescent lamp, let's say study lamp na lang pag pumalakpak ka?
Offline webscatter
  • Pogi/Ganda Points: 14
    • Webscatter Online World-WOW
« Reply #23 on: June 22, 2010, 09:43:23 PM »
meron po kacng nagpawa sa akin ng kit ,assemble lng kaso,may problema eh, bale gumawa ako bago pcb pero same ung layout nung hindi ko talaga mapagana sa pcb ko tinatry ko sa kasamang pcb ng kit.IC lang at LED at battery lng kinabit ko,pero ang problema gaun din sa unang pcb ang problem,nagiinit ang IC at nag tatrigger agad ung LED.e2 ung orig pcb with parts :
schematic :
halos kahapon hanggang ngaun kong ginagawa yan,talaga di ko man lng mapagana ng hindi nainit IC
sana matulongan nyo ako  ;D
thanks
Medyo more technical tau....
C4 is to ensure n AC ang papasok sa schmitt triggered input CMOS inverter.
R6 and R7 are voltage divider circuit...
R7 is not a bias resistor.For a supply of 5 volt, threshold voltage (Vth) must be approximately has a min. spread voltage approx. equal or near to 1.7volts (V+,min - V-,max). Meaning the negative hysteresis (V-) must be below 1.65volts(approx) and the positive hysteresis (V+) must be above 3.35volts(67%Vcc).
If the V- will not reach below 1.65 volts (33%Vcc), there is no output shift at the CMOS inverter.
After you change the R7 value, you solved the problem....
