Author Topic: panasonic flat screen  (Read 803 times)
Offline nassin
« on: March 24, 2010, 08:51:38 AM »
mga master may inayos akong panasonic ang regulator nya ay STRW6754 pag power ko umaandar pero 30 sec after mamatay mawawala na b+
Offline Simatar
  • Pogi/Ganda Points: 29
Re: panasonic flat screen
« Reply #1 on: March 24, 2010, 09:15:46 AM »
Sir post TV model number...vertical IC number.
Ano na actions nagawa mo?
Ung boltahe sa primary ecap naiistored pa ba pag shutdown?
  • Pogi/Ganda Points: 771
« Reply #2 on: March 24, 2010, 12:42:54 PM »
subcribing
  • Pogi/Ganda Points: 231
« Reply #3 on: March 24, 2010, 12:46:21 PM »
Monitor B+ at yung mga Low voltages supply 5V, 9V.
Offline nassin
« Reply #4 on: March 24, 2010, 02:45:24 PM »
mawawa ang b+ at saka 5v , 9v pag nag shut down cya 3 min after kinakapa ko ang regulator hindi umiinit
Offline nassin
« Reply #5 on: March 24, 2010, 02:48:55 PM »
pag nag shut down cya my voltahi din sa pin na strw6754 na mamawala
« Reply #6 on: March 25, 2010, 11:06:03 AM »
ilan ang measure nyo sa B+? at 5V,9V..with in 3min before shut off?
check mo mabuti marami kasi dahilan kapag ganyan trouble. try mo din sa 110V muna paganahin at set then check B+ , tapos sa 220V check ulit B+ compare mo dapat same lang ang B+ kung hindi concentrate ka sa power supply.
Offline sEPh
  • Pogi/Ganda Points: 68
  • try this_
« Reply #7 on: April 22, 2010, 02:49:32 PM »
check for cold solder..
