Author Topic: For Sale Logic IC Tester Project (schematic,source code,prototype,writeup  (Read 1866 times)
Offline engineer7@home
  • Pogi/Ganda Points: 13
  • Google Search--> Noel Rios Circuit Cellar
I have project which is a  Logic IC Tester.  It can test 74LS/HC etc.  It has a 2X16 LCD Module and a 3X4 Keypad.  The result is displayed on the LCD.  You enter the IC Number using the keypad.
I can give you the schematic, Write up,Source Code and prototype of the IC Tester.  I will also give the TTL ICs which are used to test the device.  The IC Tester uses an 16K 8051  microcontroller Because of the size of the firmware.It performs a functional test of the IC on all pins.  Please text me at 09158872962 for your best offer.  I will also accept two 10W solar panels or one Brand new Samsung Spinpoint F3 1 TB or one Brand new Western Digital 1 TB Black Caviar.
  Meet only at SM Center Las Pinas or Star Mall Las Pinas.
Here are the supported devices:  74LS,not only LS but also 74HC,74HCT.74ALS,74F since they have the same functionality but different logic levels
 74LS00
 74LS01
 74LS02
 74LS03
 74LS04
 74LS05
 74LS06
 74LS07
 74LS08
 74LS09
 74LS10
 74LS13
 74LS14
 74LS16
 74LS17
 74LS20
 74LS21
 74LS25
 74LS26
 74LS27
 74LS30
 74LS32
 74LS37
 74LS38
 74LS40
 74LS42
 74LS45
 74LS46
 74LS47
 74LS51
 74LS54
 74LS72
 74LS74
 74LS85
 74LS86
 74LS95
 74LS107
 74LS109
 74LS125
 74LS132
 74LS145
 74LS148
 74LS151
 74LS153
 74LS155
 74LS156
 74LS157
 74LS161
 74LS162
 74LS163
 74LS164
 74LS165
 74LS166
 74LS173
 74LS174
 74LS175
 74LS191
 74LS193
 74LS194
 74LS197
 74LS245
 74LS251
 74LS279
 74LS298
 74LS365
 74LS366
 74LS367
 74LS368
 74LS373
 74LS374
Love the Lord your God with all your heart & soul and with all your mind & strength.And love your neighbor as yourself.
The devil only comes to Kill,Steal & Destroy John 10:10
UKrobotics
Microcircuits gave me schizophrenia for Php2600/month in 1992
If you buy my project,you have the rights to it.  You can sell it,publish it,manufacture it etc.
I will not support the project but I guaranty that it works.  If you want support like add other Logic ICs,  I guess I have to charge you for a development fee.  You can test the FREE included Logic ICs.
For added confidence, you can view my other successful projects by doing a
GOOGLE Seach --> Noel Rios Circuit Cellar
UKrobotics
Offline ,,V, (@_@) ,V,,
Pan0 kung mali ung ic number na natype? ^^,
Wla lng!
Kung mali yung IC Number o di supported,   It will display on the LCD "Not in Library"
UKrobotics
Kunwari po 74LS107 ung ic tapos ang naitype ko ay 74LS07..
Madedetect ba nya un o ipeperf0rm parin nya ung test?
Di ba masisira ung ic?
Wla lng!
It will perform the test but it will say "Device Failed".  It also has a current detector that will signal the MCU to cut the Power to the device under test in case of overcurrent and will be displayed on the LCD.  The test will also terminate immediately in case of failure of one logic gate and not all.  The MCU also turns on the correct supply for 14 pin, 16 pin, 20 pin etc. so if you chose the wrong IC, chances are it will not have the supply to power it.  The overcurrent detector is also used in case the device under test has experience a catasthropic failure.
UKrobotics
After you have chosen which Logic IC to test, it connects the Supply to the corresponding pin, pin 14,pin 16 or pin 20.  After that, it checks the overcurrent pin.  If there is an overcurrent, it disconnects the power.  This what the logic IC tester do before testing an IC.  The  microcontroller pins are all high or in input state so it will not pull down the pin of the Logic IC when connecting the power of the device under test.  This prevents damage to the logic IC in case you entered the wrong part number.
This project is made from scratch and I did not copy or download from the Internet.  I wish to post it for Free in elabs to earn pogi points but I need the money to buy some things like a harddisk or a solar panel.
Usually, I earn USD$500 for such a project but the publisher said this project is not interesting to their readers.  That is why I am selling it.
Source code language: 8051 Assembly language
Source code file size: 148 Kbytes
Assember: Metalink Cross Assembler
Processor: Any 8051 microcontroller with Flash memory with at least 13KB like DS87C520 or AT89C55, DS89C430
Crystal: 8 Mhz
Size of Intel Hex file: 28 KBytes
Size of BIN object code: 12Kbytes
You can see from the size of the source code that this project is not made in just one afternoon or one day.  I spent many days coding it and testing it to earn the USD$500 from Circuit Cellar.  However, it was not published.
  Circuit Cellar is a great magazine.  It is a magazine for engineers by engineers.  It has good content superior to other magazines which targets just the plain hobbyist. You can subscribe to it or submit articles like I do.  This is my source of income after quitting my day job.  You can visit their website at www.circuitcellar.com for contests and COOL freebies.  This is where I get COOL,FREE hardware not just ICs.
UKrobotics
Offline Kiks
Wow. Small ATE for TTL devices.
Galing!
