Author Topic: Canon Ip1980 Series - Service Error 5100  (Read 3397 times)
Offline de PatAtas
  • Pogi/Ganda Points: 332
  • ' The unbreakable
« on: April 01, 2010, 05:23:01 PM »
' patulong po,,,sinu po sa inyo ang nakaranas na ng ganitong error ng printer,,,,Canon Ip1980 Series -  palagi po tong lumalabas,, Service Error 5100  di na po sya nag priprint,,puno po lahat ng ink,,na reset na po ang printer,,,ano pa kaya ang kulang,,,,
Offline tiktak
    • Tiktakx's Blog
Re: Canon Ip1980 Series - Service Error 5100
« Reply #1 on: April 01, 2010, 05:28:16 PM »
na experience ko ito sa canon ip1000 ko, lumalabas kahit na nilinisan na ang waste tank at head at naka ilang reset na ayaw padin kaya ayun junk na :D kinahoy ko na stepper motor at DC motor hehe total ilang taon naman na nag serbisyo
8051 stuff
  • Pogi/Ganda Points: 367
  • Design, Engineer, Create electronics circuits.
« Reply #2 on: April 01, 2010, 05:31:39 PM »
gud noon sir, there are several reasons why the error pops up. The usual causes are plastic caps getting jammed inside the gears, torn paper from a paperjam, ink spillage inside the printer. This error is generated when the printer detects that something is obstructing the carriage to and from when printing. Here are some steps that might help you.
A. Check the printer for any obstructions. or
B.1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
eto din ginawa ko sa printer ko.
http://www.tipidpc.com/viewtopic.php?tid=166122
Offline tiktak
    • Tiktakx's Blog
« Reply #3 on: April 01, 2010, 05:35:21 PM »
^hindi na din gumana method na yan sa ip1000 ko dati kaya junk na
8051 stuff
« Reply #4 on: April 01, 2010, 05:39:46 PM »
wait wait i'll show some pics....
Offline de PatAtas
  • ' The unbreakable
« Reply #5 on: April 01, 2010, 05:42:10 PM »
 'bago pa po to sir ..nabili nung July...
Offline de PatAtas
  • ' The unbreakable
« Reply #6 on: April 01, 2010, 05:47:43 PM »
' salamat po sa pag rply...ginawa ko na po ito,, pro di pa rin nag work,,,gusto ko pong operahan tung prinTer na to kaso parang may warranty pa..kasi bago pa..,nangigigil ng mga daliri ko..
Offline tiktak
    • Tiktakx's Blog
« Reply #7 on: April 01, 2010, 08:15:35 PM »
pa warranty mo nalang sis
8051 stuff
Offline >>>???<<<
  • Pogi/Ganda Points: 530
« Reply #8 on: April 01, 2010, 09:20:17 PM »
Subukan mo ireset uli yung printer then reboot CPU with printer still on. Baka makuha sa ganito. Or/then refresh mo uli printer mo sa printer and faxes folder.
http://www.elab.ph/forum/index.php?topic=41860.0 My DIY transformer... ? ? ? Test Build Uli
http://www.elab.ph/forum/index.php?topic=33717  I2c / spi programmer
http://www.elab.ph/forum/index.php?topic=37150.0 Lcr esr makikigulo rin ba kayo ??? Test Build
http://www.elab.ph/forum/index.php?topic=29963.0 Esr collection na malamig
http://www.elab.ph/forum/index.php?topic=25854.0 Basic C++ Programming Tutorials by Prof Asimo
Offline de PatAtas
  • ' The unbreakable
« Reply #9 on: April 13, 2010, 02:44:46 PM »
' salamat po sa lahat na nag reply..ok na po ang Printer ko,,
SPECIAL THANKS TO THT FF. PERSON
 tiktak
 insomartin
 Jassharing
« Reply #10 on: April 13, 2010, 03:09:50 PM »
Asteeg! at lease hindi na junk.
Offline >>>???<<<
« Reply #11 on: April 13, 2010, 03:32:00 PM »
Hehehe nakalusot na naman sa bagong printer.   ;D
Offline de PatAtas
  • ' The unbreakable
« Reply #12 on: April 13, 2010, 03:35:10 PM »
 ' hehehe..dahil sa inyo...naligtas..
