Author Topic: Countdown timer ung 74ls192,, pahelp poh.  (Read 2291 times)
Offline reymer555
  • me!
« on: April 11, 2010, 12:11:57 AM »
pede po pahelp,, pde patulong, panu po maiistop ung counting using ne555, 74ls192 at 74ls47, ung counting nya po is countdown ung prob ko lang, d ko mapastop ung counting pag dating nya sa zero.. sana po may magrepz at magbigay ng schematic diagram for better understanding,,ASAP!!
Offline nucleus
Re: Countdown timer ung 74ls192,, pahelp poh.
« Reply #1 on: April 11, 2010, 12:19:07 AM »
use nand gates to detect kung zero yung output nya :) then ilagay sa reset pin ng 555 yung output
Offline reymer555
  • me!
« Reply #2 on: April 11, 2010, 01:12:12 AM »
pero dba ung carry ng 74ls192 is naka HIGH at mag lolow lang pag naachieve na nya ung last state nya?
Offline motion55
  • Pogi/Ganda Points: 244
« Reply #3 on: April 11, 2010, 06:19:22 AM »
Diba countdown ang kailangan mo? The borrow signal goes low when the outputs Qa,Qb,Qc and Qd are all low. Use this signal to stop the clock when the count is equal to zero.
"Set your mind free!"
Offline reymer555
  • me!
« Reply #4 on: April 11, 2010, 01:51:50 PM »
pero po ung una kac lumalabas sa counting is zero e, pag ginawa ko ung bali d sya mag cocount kac, nakalow na ung borrow agad.. T.T
Offline Redskin
  • Pogi/Ganda Points: 13
« Reply #5 on: April 11, 2010, 08:40:28 PM »
preset mo ang input example 99 see the 24 sec shot clock project search mo lang dito sa elab
Offline carlsfootprints
  • Pogi/Ganda Points: 25
« Reply #6 on: April 11, 2010, 11:11:40 PM »
http://www.electronicslab.ph/forum/index.php/topic,15719.0.html
ikaw pala may gawa nito redskin.. hehe...
@reymer,
check mo link sa taas.. makakatulong sayo yan..
gamitin po natin ung search ng forum..
never saturate..
Offline glenntacan
« Reply #7 on: May 03, 2010, 12:02:33 AM »
guys ganito rin ang hinahanap ko para sa advance logic project namin.
yung countdown timer po na from 10 minutes to zero.
kung saan-saan na akong site naghanap ng solusyon sa problema kong ito at sana po may makatulong po dito sa akin.
kailangang-kailangan ko po ang schematic diagram kasi hindi ko ma-build ang project pag wala ang timer.
please po pahingi ng schematic nito.
salamat po.
mabuhay
Offline jogz44
« Reply #8 on: November 18, 2010, 01:45:14 PM »
mga bossing meron din po kami project na magset ka ng time tapos magcountdown na cya,192 din po gamit namin,ok na po yung countdown yung pagset nalang po gamit na po ako debouncer kaso mali mali yung increment nya po... help po pls...
Offline updated
  • Pogi/Ganda Points: 22
« Reply #9 on: November 18, 2010, 02:55:24 PM »
^ano po appoarch na ginawa mo pag set? sa increment po kau naglagay diba? baka po may mali sa debouncer nyo. natry mo ba sa parallel load?
Offline jogz44
« Reply #10 on: November 18, 2010, 03:02:59 PM »
natry ko po yung debouncer circuit sa 74ls90 po ok naman po cya...
Offline updated
« Reply #11 on: November 18, 2010, 03:11:43 PM »
ano po ba yung na encounter mong mali? multiple input po ba?  isolate mo kung saang part yung problem. para dun ka nlng magfocus sa part n yun.. u can post your schematic here
Offline jogz44
« Reply #12 on: November 18, 2010, 03:22:30 PM »
doon nalang po sa part na count up na manual po....try ko po i-post maya po nandun kasi sa kaklase ko yung schematic..baka po meron kang debouncer circuit na tested mo n po...ang mali po ay pag press mo po mali2 po yung labas...
Offline jogz44
« Reply #13 on: November 20, 2010, 04:50:27 PM »
boss di pa ako pwede mag post ng link..
Offline thevenin
  • Pogi/Ganda Points: 19
« Reply #14 on: December 11, 2010, 02:07:28 PM »
madali lang yan sa 74192 mo i-stop.pag nareach na ang zero eh i-feed mo sa reset ng 74192.consider mo kung active high o active low ang bawat pin ng ic..data sheet ang da best na reference niyan at pagaralan mo ang timing diagram ng 74192..dapat kasi alam mo kung paano gumamit ng datasheet..
GOODLUCK!..
Offline kunimitzu
  • Pogi/Ganda Points: 4
« Reply #15 on: May 01, 2012, 07:39:45 PM »
sa tingin ko po baka pwede maglagay ka ng AND gate sa output ng 555 timer, un ung 1st input ng AND gate, 2nd input ay galing sa pin 13(TCD) ng 74192, since pin 13 is low kapag ang count is 0... kaya kapag 0 ang count, ang 2nd input ng AND gate ay low(0) kaya kahit 1 ang output(1st input of AND gate) ng 555 timer, since 0 ang 2nd input, 0 din ang output ng AND gate...  ;D
