Author Topic: help panasonic TC-21GX10PS vertical shrink to 2 inches with rainbow  (Read 1334 times)
Offline thomz
  • Always follow the golden rule....
mga masters help naman yong picture lumiit vertically tapos may parang rainbow sa dulo. naguluhan ako sa 2 regulator nakasulat value OOBCOW tapos sa baba 748 H06 2 ginamit nya nito magkaiba sukat voltage tapos yong micon TDA11115H1/N2/3 baka may schematic kayo nito makahingi na rin kung pwede. thanks
Offline thomz
Re: help panasonic TC-21GX10PS vertical shrink to 2 inches with rainbow
« Reply #1 on: April 23, 2010, 05:29:53 PM »
dagdag ko lang mga masters wala din pala sound pero paglipat channel magkakaroon pero mawawala din agad . yong regulator na sinasabi ko 5 pins 5 volts regulator siguro yon. yong isa IC851 pin 1=3.3 volts 2=9.5 3=0 4=5  5=1.4 tapos yong IC880 pin 1=2.6 volts 2=10.2 3=0 4=3.4 5=1.5 pareho nakasulat sa 2 regulator OOBCOW 748 HO6. thanks sana matulungan nyo ako, kakaiba kasi para sa akin yong problem
Offline sEPh
  • Pogi/Ganda Points: 68
  • try this_
« Reply #2 on: April 23, 2010, 10:45:11 PM »
kelangang pasukin yung service mode.yung tanung,paano? ;D
wala bang FA1 saka FA2 dyan?
Offline thomz
« Reply #3 on: April 23, 2010, 11:15:06 PM »
sir ano ba yong FA1 at FA2?
Offline thomz
« Reply #4 on: April 24, 2010, 12:12:40 PM »
update lang nakkuha ako diagram although hindi ka model pwedeng reference. yong 2 regulator na nabanggit tama voltage output. supply sa vertical ok din. hindi kaya posible na may tama vertical IC tapos nag protect sya kaya pati sound apektado? na try ko na rin kasi i shunt mga ecaps sa vertical section pero gnun pa rin. ano sa palagay nyo mga masters ? response naman dyan. value nga pala ng vertical AN15525A
Offline sEPh
  • try this_
« Reply #5 on: April 24, 2010, 10:23:09 PM »
Factory Adjustment...tingnan mo kung mayrong nakasulat sa board, sa taas banda malapit sa tuner.
Offline nucleus
« Reply #6 on: April 25, 2010, 01:06:36 AM »
lagyan mo din ng antenna may mga unit na nagmumute kapag walang narerecieve na station, sa vertical naman check mo po yung 100uf na capacitor papuntang pin3 pump up, tsaka yung filter capacitor sa pin2 tsaka yung 1000uF capacitor at 1 ohm resistor na nakaseries sa yoke paki check narin :)
Offline thomz
« Reply #7 on: April 25, 2010, 06:28:13 AM »
salamat mga masters mamaya gagawin ko yong mga sinabi nyo tapos update ko kayo
Offline thomz
« Reply #8 on: April 25, 2010, 09:54:00 PM »
nagka sound nga nung may antenna master nucleus, pero nag shunt ako mga ecaps wala pa rin normal naman voltage at ok rin mga resistors  kaya vertical IC talaga salarin. ang problem di available AN15525A dito. baka may alam kayo substitute sa ganito IC pa help na rin. +1 sa inyo master nucleus at master seph, salamat
Offline nucleus
« Reply #9 on: April 25, 2010, 11:54:51 PM »
AN15526 pwede dyan
Offline thomz
« Reply #10 on: April 29, 2010, 09:53:40 PM »
ok thanks, pro binalik ko na tv wise yong may ari gusto pabayaran sa kin vertical IC pag napalitan at di gumana.tnx sa inyong lahat. share ko na rin to http://www.electronicslab.ph/forum/index.php/topic,12894.0.html
Offline nucleus
« Reply #11 on: April 29, 2010, 11:02:34 PM »
kaasar yang ganyang customer walang tiwala sa naggagawa
Offline thomz
« Reply #12 on: April 30, 2010, 06:47:09 PM »
oo nga eh di nila alam kung gano kahirap work natin. wala tayo magagawa eh. salamat sa lahat mga masters
Offline enriz622
  • Pogi/Ganda Points: 287
« Reply #13 on: May 06, 2010, 07:19:19 AM »
dapat inangat mo yung anode cap ng fbt at pinahawak mo sa may-ari ng tv :D:D
  • Pogi/Ganda Points: 771
« Reply #14 on: May 06, 2010, 08:34:37 AM »
mayron pong mababang value ng ecaps dyan malapit sa jungle IC connected po sya sa vertical mga 1uf to 10uf nangyari na sa akin yan kala ko wala ng ibang vertical ecaps nung makita ko ang 2 ecaps malapit sa jungle pariho ng code sa vertical hehehe kasama pala sya pagpalit ko ok na agad ang unit. sana makatulong ito sayo
Offline enriz622
« Reply #15 on: May 06, 2010, 10:57:39 AM »
minsan iba ang kulay nyan sa mga capacitor na nakalagay,minsan color red or brown
Offline sEPh
  • try this_
« Reply #16 on: May 06, 2010, 07:08:51 PM »
mga sir, binalik na daw po yung tv...
« Reply #17 on: May 07, 2010, 08:00:03 AM »
 ;D ;D ;D ;D
Offline enriz622
« Reply #18 on: May 07, 2010, 08:15:24 AM »
baka technician din yung may-ari :)
