Author Topic: Paano magrecord sa Souncard ng nde na pinadadaan sa microphone?  (Read 2046 times)
Offline BANNEDMemberAccount
  • Pogi/Ganda Points: 130
pano ba yun?
Re: Paano magrecord sa Souncard ng nde na pinadadaan sa microphone?
« Reply #1 on: April 23, 2010, 04:19:42 PM »
ganyan ba :)
Offline pintac
  • Pogi/Ganda Points: 5
  • e pluribus unum
« Reply #2 on: April 23, 2010, 05:39:16 PM »
Play nyo lang tapos click the record.
« Reply #3 on: April 23, 2010, 07:32:17 PM »
tama ba ikokonect lang ang sa speaker at sa mic jack?
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #4 on: April 23, 2010, 08:51:38 PM »
bat di mo gamitin ang Line in?
WootsPC2 Videos  Woots Page
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
« Reply #5 on: April 23, 2010, 08:54:47 PM »
yup line in yun ginagamit ko pag transfer ako from cassette to CD :D
8051 stuff
« Reply #6 on: April 26, 2010, 08:33:07 PM »
pano gamitin ang line in? :)
Offline brian_po
  • Pogi/Ganda Points: 40
  • Babaero ka ah
« Reply #7 on: April 27, 2010, 11:59:34 AM »
yun input ng mic. line in yun  :D
-Conserve Water; Drink Beers
« Reply #8 on: April 27, 2010, 12:36:19 PM »
based dun sa diagram gusto mo i record yung lumalabas sa speakers mo. sa windows xp yung output nang sound card pwede mo na irecord direct from software. kailangan mo lang iselect if midi,mic,main,cd,linein yung gusto mo ma capture...
« Reply #9 on: April 27, 2010, 01:56:59 PM »
^ mukhang may ire-record siya sir na circuit ang input.
parang ganyan din, pero walang built-in preamp 'yung line in. kailangan ikaw maglagay nung signal sa line level.
BTW, kung malakas volume nung speaker output nung circuit na pinanggalingan, kailangan mo lagyan ng attenuator dahil ma-overdrive naman 'yung line in or mic input nung soundcard. magiging clipped ang recorded audio mo.
Offline pintac
  • e pluribus unum
« Reply #10 on: April 28, 2010, 08:43:40 AM »
Kung may line-out yong device pwede tong isakasak sa line-in. Makontrol mo sound/signal level via souncard/speaker o sound mixer properties. Pwede gamit ka ng Audio soft (Cakewalk, Magix, Audition etc.) para mas may control sa freq. response.
Pwede rin speaker-out saksak sa line-in pero minimize mo volume at lagyan ng 7.5 ohms series .5 or 1 ohms ohms yong speaker out (dapat tanggal ang speaker) sa .5 o 1 ohm ka kumuha ng signal para weak signal lang at wag masaturate ang line-in.
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #11 on: April 28, 2010, 01:08:06 PM »
i recommend to use usb soundcards for experiment
kasi kapag napasukan ng unwanted signal yang onboard soundcards
sayang kung masisira.
« Reply #12 on: April 30, 2010, 01:28:37 PM »
sir kung lagyan ko kaya ng preamp ang speaker output para maiconnect ko sa MIC jack. pwedi na ba yan o malakas pa ang preamp na yan ?
thanks
« Reply #13 on: May 01, 2010, 11:46:09 PM »
naku, malakas na ang speaker output. dapat nga attenuator pa ang ikabit mo.
« Reply #14 on: May 02, 2010, 08:14:19 PM »
^ hehe thanks sa reply
 yung pot lay sir RPZ palitan ko nalang ng resistor mga 10k or 1k para bumaba ang output? pewdi kaya :)
« Reply #15 on: May 02, 2010, 08:17:29 PM »
tanong ko lang baket kailangan pa magseries ng 1ohms if nafifilter naman ng .5 ohm yung output? sensya na medyo nde paako gaano magaling sa circuit :)
« Reply #16 on: May 02, 2010, 08:47:18 PM »
^ masyado kasi mataas ang output ng speaker out, kung sa earphones, around 1V to 2V, e around 1V lang ang line level sa mga soundcards. kung sa Mic In pa ipapasok, meron pang pre-amp 'yun. so kung papasukan ng around 1V 'yung Mic In, basag ang mare-record (clipped kasi) and pwede rin masira 'yung circuit sa loob.
« Reply #17 on: May 02, 2010, 09:00:42 PM »
attenuator lang talaga solution :) yung ba yung ko-controlin ang volt para maging fix value lang, series ng resistor? :)
« Reply #18 on: May 02, 2010, 09:21:45 PM »
sir pwedi na ba yan ano ang  coil dapat?
Offline pintac
  • e pluribus unum
« Reply #19 on: May 02, 2010, 09:27:33 PM »
Sa earphone-out pala kayo kukuha para sa mic-input? OFF nyo lang yong Mic Boost ng sound card, nasa properties ito.
Salpak na ninyo yan, adjust nyo lang sa minimum ang volume ng earphone.
