Author Topic: pcb drill press..  (Read 3228 times)
Offline emjhay10
pcb drill press..
« on: April 23, 2010, 08:04:13 PM »
need help po.. san po nkakabili ng pcb drill press ngaun? ung mura lang po.. salamat po :)
pcb drill press..
Offline OPTIMUS PRIME
  • Pogi/Ganda Points: 28
Re: pcb drill press..
« Reply #1 on: April 23, 2010, 08:57:39 PM »
San mo gagamitin sis.?kung purely PCB di na need yun.
Practice lang need mo buy ka na lang ng drill. Check e-gizmo
Offline emjhay10
« Reply #2 on: April 24, 2010, 11:04:55 AM »
hehe thankz po.. hndi po tlga ako ung gagamit, ung klasmeyt ko po, kealang need po kc nming palitan ung drill press na nasira nmin  sa kanya, ung katulad po sa deeco, ung drill po na may stand pang press.. wala na daw po kcng gnun eh.. may alam po ba ikaw?? kung san nakakabili ng gnun? sana po meron.. tnx2 po
« Reply #3 on: April 24, 2010, 11:54:51 AM »
ganun ba. Why need to buy for a replacement e alam na naman nya madaling masira. Yayain nyo na lang mag outing libre nyo baka things will get settled. Check mo na lang Deeco Cubao or Alabang if that is your intentions
Offline emjhay10
« Reply #4 on: April 24, 2010, 10:33:08 PM »
hehehe oonga po eh, tama po kayo, kainis na nga eh, apurado pa actually hndi po tlga sira un, ngana pa po ung drill, ung pinkabase lang ung sira kasi puro butas na ng drill bit ung ilalim, tabingi na din kc.. weh kung ok lng nga po sa knya na ganun n lng eh, matagal na namin pong gnawa, libre lhat hehehe.. kaso mukang hndi tlga.. cge po madaming salamat.. ccheck ko na lng din po.. sana meron pa.. pro kung may alam pa po kayo na may gnun, khit hndi po gnun ang itsura, basta mura hehe, blitaan nyo na lng po ako.. salamat :)
Offline iyo karpo
  • Pogi/Ganda Points: 18
« Reply #5 on: April 25, 2010, 09:57:44 PM »
PCB lng ang dinidril mo. Kailangan mo pa ng drill press?
Makapal ata ang PCP nayan??
Drill press ang ginagamit sa pagdrill ng backpanel.
  • Pogi/Ganda Points: 631
« Reply #6 on: April 26, 2010, 01:55:47 AM »
^ I think they're referring to this sir. guide, para laging 90 degrees ang butas.
meron ako sa bahay ganito lang,hehehehe
BTW, gumagamit ako ng Drill Press to drill PCB lalo na kapag FR4 material at maraming butas and especially kapag double sided. medyo matrabaho magbutas ng FR4 kung 'yung mga maliliit na hand drill ang gamit. eto ang reason kaya 'yung mga drill bit ko sa bahay is mostly HSS with 1/8" shank. pwede sa drill press, pwede rin sa hand held high speed rotary tool (like Dremel, pero Black and Decker gamit ko).
Offline nucleus
« Reply #7 on: April 26, 2010, 01:57:11 AM »
mas stable sir pag drill press, iwas makabali ng drill bit
yung gamit ko na drill press para sa PCB 1/3HP @ 3450 RPM yung motor ;D then 5:1 yung pulley 17,250 RPM yung ikot ng 1/4 na chuck maganda yung finish ng butas :)
« Reply #8 on: April 26, 2010, 02:02:24 AM »
^ agree. 1/2 HP naman sa bahay. mas mabilis din ang trabaho at mas pulido. at mas pantay pantay din.
iwas putol din ng maninipis na drill bit (less than 1mm)  dahil diretso lang ang labas at pasok.
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
« Reply #9 on: April 27, 2010, 05:40:14 PM »
@nucleus @rdpzycho - san nyo nabili drill press nyo and magkano?
« Reply #10 on: April 27, 2010, 05:44:42 PM »
1/3 HP din saken
sa raon, 3500 bili ko ata=) last year pa yun..
malapit lang sa isetann =)
EDIT:
2200 pala bili ko,, kasi two yung option ko nun yang tig3500 at tig3500
ito yung akin =)
« Reply #11 on: April 27, 2010, 06:02:34 PM »
naku sir, mas matanda pa sa akin 'yung drill press dito. tatay ko apa nagpkundar noon. hehe. medyo makalog na kapag mabilis, pero ok pa naman.
 iwasan niyo lang 'yung mga murang maliliit, pangit bearing sa quill noon.
Offline nucleus
« Reply #12 on: April 28, 2010, 01:53:06 AM »
yung sakin mas matanda din sakin ;D nung 2008 lang binili ng tatay ko rockwell ang tatak, tingin ko dating ginamit sa mano manong pcb fab dahil sa punong puno ng pulbos na pcb yung loob ng motor nung kakabili palang nilinis namin, kahit na luma wala pang kakalog kalog ito mas mabigat din sakin ito ;D ;D ;D
Offline franzschluter
« Reply #13 on: April 28, 2010, 02:59:33 AM »
You can get this cheap sa makro. Nasa 2k+ din nung nakita ko promo nila na handouts.
Sa drill bits though.. Wala ako makita available sa pinas out of carbide ung maliliit like 0.3mm. Puro HSS lang which IMO is not so good as it tends to break every now and then. But in contrast its dirt cheap.
Trivia:
As a rule thumb as a machinist
The smaller your bit is, the higher you need to raise your RPM.
The bigger your bit is, the lower you need to slow down your RPM speed.
By doing so, you will save money in spending for new bits.
This is why a good drill press must have at least 3 variable speeds.
Offline Roland
  • I always compete to myself
« Reply #14 on: June 07, 2010, 01:40:31 PM »
1/3 HP din saken
EDIT:
ito yung akin =)
ganda ng drill press mo sir, tsaka ung mga beauty products mo na nasa tabi.
Offline bmall
  • Pogi/Ganda Points: 10
  • pinoy geek
« Reply #15 on: June 14, 2010, 11:51:53 PM »
here's another sample of a PCB drill press for your reference :
Striving to be an official gadget freak !
« Reply #16 on: June 18, 2010, 09:30:29 AM »
very nice tulo laway na lang
Offline Mayor Johnaray
  • Pogi/Ganda Points: 238
« Reply #17 on: June 18, 2010, 10:49:33 AM »
Drool .... hanggang tingin muna ako
Offline bravokilo
  • Pogi/Ganda Points: 104
« Reply #18 on: July 01, 2010, 02:51:46 AM »
I have a table drill press like the one of kaiser. Hardly used. Will sell for P2,500.will post pix.
Pls text me interestedparties. Kuya Bong:0922 281 0680
BK
Offline ladythug
« Reply #19 on: July 01, 2010, 03:31:30 AM »
hi..ask q lng e2 ung nkuha kung topic d2 "ADAPTIVE TECHNOLOGY FOR BLIND "..so paano po ba yan?..need ur answers..tnx :-)
