Author Topic: pcb drill press..  (Read 3237 times)
Re: pcb drill press..
« Reply #20 on: July 01, 2010, 08:56:29 AM »
yung drill press ko..ilang months ko syang di nagalaw... ngayon pag nagddrill ako nalalaglag yung chuck nya.. ano ba dapat gawin ko dito :D
Offline bravokilo
  • Pogi/Ganda Points: 105
« Reply #21 on: July 01, 2010, 10:58:21 AM »
Kaize, kung hinde screwed on yung chuck, pinapalo lang yan upwars pero hinde dun sa colett nya. gamitin mo kahoy pukpok mo sa kahoy and the kahoy tumatamadun sa gilid ng colett, sa housing ng chuck. Yung colett ay yung 3 iniipit and bit.
BK
« Reply #22 on: July 01, 2010, 11:02:16 AM »
BK
sige sir... try ko..thanks=)
simula kasi nung nabili ko yung hand drill ko.. lalong di ko nagamit eh heheh..
Offline OPTIMUS PRIME
  • Pogi/Ganda Points: 28
« Reply #23 on: July 01, 2010, 09:50:11 PM »
correct si BK....wag metal to metal baka mag off nman ang alignment..
OT: mas ok na pala sayo sis yung hand job
Dont worry about failures but worry about the chances you miss if you dont even try...........
« Reply #24 on: July 02, 2010, 01:01:22 AM »
kawawa naman... tsk
Offline mvs sarma
« Reply #25 on: July 02, 2010, 02:01:15 AM »
^ I think they're referring to this sir. guide, para laging 90 degrees ang butas.
BTW, gumagamit ako ng Drill Press to drill PCB lalo na kapag FR4 material at maraming butas and especially kapag double sided. medyo matrabaho magbutas ng FR4 kung 'yung mga maliliit na hand drill ang gamit. eto ang reason kaya 'yung mga drill bit ko sa bahay is mostly HSS with 1/8" shank. pwede sa drill press, pwede rin sa hand held high speed rotary tool (like Dremel, pero Black and Decker gamit ko).
I use this model and works fine for me. Definitely a useful tool for hobby work.
Let us share knowledge, we too gain by the way.
Offline Tarkov24
« Reply #26 on: July 25, 2010, 09:14:50 PM »
ganun ba. Why need to buy for a replacement e alam na naman nya madaling masira. Yayain nyo na lang mag outing libre nyo baka things will get settled. Check mo na lang Deeco Cubao or Alabang if that is your intentions
san po ung Deeco sa cubao???
BANANA YELLOW IS A HAPPY COLOR!!!
Offline iyo karpo
  • Pogi/Ganda Points: 18
« Reply #27 on: July 26, 2010, 04:40:09 AM »
pareho ba ang kailangang rpm sa kahoy at metal.
Offline bravokilo
« Reply #28 on: July 26, 2010, 08:17:34 PM »
Pjarina sis. speed doesn't really matter to me pag hi speed dril lbit naman nakakabit. Howevr, tis is for thin wood./ pag makapal, uusog na yung wood kaya you have to slow down. Di mo naman pwdeng less pressure like for metal sheet drilling dahil nakabaon na and bit mo sa wood. Yung fan belt ay nililipat. Mailiit sa motor, malaki sa drill.
     By the way, I have 3 electric drills na sira na ang rechargeable battery.  Gamit ko ay yung SLA pang lantern na 6V, na 4AH yun! nakatali sa ilalim. Gumawa ako ng small adaptor charger para dito. Works fine.  I have a Craftsman binili ko sa Walmart sa Tatenoon. Di ko ginagamit. $50 ang bili ko na may case siya. Ok pa battery at pwede naman pa repack sa ELFOH sa Raon. Or sub C ata, we can replace it. If somewant wants it for P1500, I will let it go. Yung mga iba, pwede sa P900. Excellent to make into PCB drill press. Use a small car shock absorber. Remove the fluid, movable ang shaft nun.Attach the electric drill dun.
 :D :D :DBK
Offline iyo karpo
« Reply #29 on: July 26, 2010, 08:25:51 PM »
Bakit ung wireman sa sa shop ko - insist sya na pag stainless steel plate mas mababa ang speed at iba ang drill bit?
Offline NanotecH
« Reply #30 on: July 27, 2010, 07:21:37 AM »
depende sa material na bubutasan may iba't-ibang klase ng drill bits (material, coatings, etc).
pag stainless steel kailangan talaga mabagal lang at, at least, cobalt steel alloy,
puede rin ang high speed steel pero di magtatagal ang bits.
yung iba gumagamit ng cutting fluid/lubricant/coolant para tumagal ang mga bits.
kadalasan mas maraming gumagamit ng high carbon steel dahil sa mas mura kumpara dun sa iba.
ang nangyayari nga lang bili lang ng bili ng bago pag mapurol na.
220V/10A input = 220V/30A output...Fact or Fiction?  Myth or Reality?
One word is enough for a wise man.
"Never tell the truth to people who are not worthy of it." - Mark Twain
« Reply #31 on: July 27, 2010, 12:23:02 PM »
^ o kaya naman hahasain ng hahasain hanggang maubos 'yung talim. ;D
'yung talim na pangkahoy talaga merong mas maliit at matulis na dulo (centering point ata tawag doon).
« Reply #32 on: July 27, 2010, 12:29:54 PM »
^ same here. kung pwede lang mahasa sa grinding wheel yung pang pcb drill malamang nagawa ko na.
very familiar yung gamit nyang dro dito...  :-*
Offline NanotecH
« Reply #33 on: July 27, 2010, 03:25:01 PM »
kung hindi naman sobrang liit ng bits puede na rin yung portable drill bit sharpener,
« Reply #34 on: July 27, 2010, 06:51:10 PM »
Mga sis itong paghahasa sa drill bit is being done sa talyer namin. Di masyado ok pero pag medyo matigas ang trabaho at napurol ang bit gina grind na lang in an angular position na parang sa orig. Though di ganun ka okey ...wag lang uminit ng todo during grinding para wag mawala ang treatment ng metal pede na kesa bibili ng bagong bit for the same price ng trabaho. Use lang ung lathe machine at bato ng rotary grinder
« Reply #35 on: July 27, 2010, 09:58:46 PM »
sa pinapasukan dati ng kasama ko, pati 'yung mga 0.5mm na bit hinahasa pa. ;D
« Reply #36 on: July 28, 2010, 04:11:37 PM »
Reverse polarity ang drill tapos honning stone ba gamit nya sis?
