Author Topic: kailangan ko po ng regulator para pure 12vdc ang output ko need help  (Read 1543 times)
Offline onepiece
may alam po ba kau na diagram para maregulate ko yung 100+na dc output ko into pure 12vdc na lang??
anong klase at value po ba ng diode ang pwede ko gamitin,,
may nakapag sabi kc saken na gamitan ko raw ng "IC LM7812 ung output ko tama rin ba yun ??
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
Re: kailangan ko po ng regulator para pure 12vdc ang output ko need help
« Reply #1 on: April 26, 2010, 11:15:59 AM »
35volts lang ata po ang max input ng 7812 sir, check nyu din po ang spec sheet..
Offline Heuriskein
  • Live each day as if it is the last ...
« Reply #2 on: April 26, 2010, 11:33:08 AM »
Correct me if i'm wrong but sa pagkakaalam ko about LM7812  Its maximum input voltage should be near 35 volts,minimum input voltage is around 14V and the output is a regulated 12V. IF you have multisim installed merong design don using LM7812 but 20V lang ang input or you can dig in this site for more power supply design http://www.capetronics.com/info/schematics.htm
« Reply #3 on: April 26, 2010, 02:43:16 PM »
san galing yong 100vdc mo?
 kong 100vdc mataas masyado para sa lm7812 yan.  gamit ka nalang ng psu ng DVD pasuk mo sa main capacitor ng primary ng dvd ang 100vdc sigurado may 12vcd kana regulated.
Offline onepiece
« Reply #4 on: April 27, 2010, 04:32:48 PM »
ano po bang dvd yan? dvd player po b yan?
« Reply #5 on: April 27, 2010, 04:34:00 PM »
opo
  • Pogi/Ganda Points: 909
« Reply #6 on: April 27, 2010, 05:51:28 PM »
SMPS module (^_^
Offline Mr. D
  • Pogi/Ganda Points: 369
  • "Agta Maloko"
^ TAMA, ang galing mo tatay pete.
yung regulator na 78series at 79series ang alam ko 1.+ amp. lang ang current capacity nyan, pero yung SMPS ng dvd player sometimes yung 12V out nyan nasa 2~3.+ amps. ang current capacity..
Good Guys Never Hide
Offline nucleus
ang tanong ano po ang source mo ng 100V? ito ang important para makapagrecommend ng nararapat na regulator :)
Offline nucleus
pwde rin na ang input nya ay 100 volts para sa 7812 fix regulator
ano ba ang ginagawa ng mga dropping resistor kung poproblemahin natin ang taas ng input voltage nya?
diba?
pwede naman talaga pero mababa ang efficiency
Offline nucleus
« Reply #10 on: May 01, 2010, 11:46:45 PM »
depende sa gagamitin nyan load di ba master?
saka medyo kulang ang detail ng ts kung saan galing ang 100 volts nya
yup
Offline nucleus
« Reply #11 on: May 01, 2010, 11:50:56 PM »
pwd kaya yang 7812 sa input na 100v 0.005A?
hehehehehe
hindi na siguro gagana
  • Pogi/Ganda Points: 630
« Reply #12 on: May 01, 2010, 11:58:55 PM »
ang problema sa dropping resistor, kailangan may certain amount ng current para merong certain amount ng voltage drop sa resistor. kung may dropping resistor then 7812 tapos walang load, sibak kaagad 'yung 7812.
mas maganda pa ang series zener, or kung AC ang source, capacitive divider.
BTW, sa case ng dropping resistor regulators, mas preferred ko ang parallel type regulator.
« Reply #13 on: May 02, 2010, 05:24:49 PM »
master pwde na ba ang resistor na gawing load sa 7812?
pwede yan sir
« Reply #14 on: May 02, 2010, 08:40:08 PM »
^ nope.
« Reply #15 on: May 02, 2010, 08:48:03 PM »
7912 - negative output, 7812 - positive output (with respect to Ground). ;)
« Reply #16 on: May 02, 2010, 09:04:39 PM »
ah ok bro!
pwede rin po bang iconnect in series ung 7812 para  magkaroon ng 24 volts?
defende  rin sa pagkakaseries
« Reply #17 on: May 02, 2010, 09:52:05 PM »
yup pwede naman. basta ang mine-maintain ng 7812 na 12V ay 'yung Out to Ground, kaya pwedeng i-exploit 'yung. ;)
pwede rin ngang gawing adjustable 'yan. actually, 'yung LM317 mas maayos lang 'yung ibang parts ng circuit (internally), pero similar 'yan sa 78xx regulator na naka 1.25V fixed output.
