Author Topic: MPLAB IDE to ic-prog programmer  (Read 928 times)
Offline doodleskram
« on: April 29, 2010, 10:14:55 PM »
mga sir/ mam patulong naman po... nag install po ako ng MPLAB and balak ko gumawa ng JDM based programmer tapos nagdownload ako ng IC prog. tanong ko lang po kung yung program na ginawa ko sa mplab is pwede ko magamit para matransfer sa pic using ic-prog?
Offline 0b00000111
  • Pogi/Ganda Points: 398
Re: MPLAB IDE to ic-prog programmer
« Reply #1 on: April 29, 2010, 10:19:10 PM »
yup... yung magegenerate na hex ng mplab, is open mo lang sa ic-prog.
Tel #: (63)(2) 536-3378
Globe +63915-973-7691
Smart +63921-779-0748
Location Map
Offline doodleskram
« Reply #2 on: April 29, 2010, 10:50:16 PM »
salamat po sa reply... tanong ko lang po kasi nung binuksan ko yung nadownload ko na ic-prog is lumalabas is privileged instruction. dapat po ba kapoag binuksan ko sya is nakaconnect na yung pinakahardware... pacencia na po bago lang ako po dito ....
Offline macky
  • Pogi/Ganda Points: 51
« Reply #3 on: April 30, 2010, 12:02:49 AM »
Just right-click the ic-prog.exe then choose Properties, then select compatibility mode with windows 98/me, then click Ok.
john 3:16 | oil of gladness
Offline webscatter
  • Pogi/Ganda Points: 14
    • Webscatter Online World-WOW
« Reply #4 on: May 12, 2010, 04:23:58 PM »
MPLab IDE can be C, BASIC, ASM or maging HEX...so play around para sa IC Prog mo
Offline doodleskram
« Reply #5 on: May 18, 2010, 12:44:34 PM »
salamat po. kaso sir nung nagcontruct ako ng programmer ko yung uJDM programmer naitesting ko na using ic-prog 1.06B kaso nung lalagyan ko na ng program ang lumalabas is program code failed at 0x000h. tapos kapag binerify ko is verify failed at 0X000h. yung naconstruct ko na JDM based na programmer is nakabreadboard muna kaso ganun ang nalabas... then tinatry ko ding iblank check kaso ang lumalabas is deivce is not blank at 0X000h. mga sir pano kaya yun?
  • Pogi/Ganda Points: 203
« Reply #6 on: May 18, 2010, 02:18:19 PM »
winpic800 nalang :D
Offline ed
  • Pogi/Ganda Points: 6
« Reply #7 on: May 18, 2010, 03:37:01 PM »
opo sir try mo ung winpic800.....un din gamit eh...and jdm programer....ok naman...
Offline bluegirl
  • ..........me..........
    • author lang aq dito
« Reply #8 on: June 21, 2010, 11:52:18 PM »
saan makaka download ng program na mplab?
“Mathematics is made of 50 percent formulas, 50 percent proofs, and 50 percent imagination.”
Offline 0b00000111
« Reply #9 on: June 22, 2010, 12:27:03 AM »
Location Map
Offline bluegirl
« Reply #10 on: June 22, 2010, 12:57:03 AM »
www.microchip.com
cge tnx po... gusto q na matutuo using pic 16f84a...
« Reply #11 on: June 22, 2010, 01:26:00 AM »
mas ok na "pagaralan" ang pic.
