Author Topic: RTOS for mini MOBOT  (Read 4443 times)
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
Re: RTOS for mini MOBOT
« Reply #20 on: April 04, 2008, 03:47:37 PM »
Try mo microCos/ uCos-II
download here: http://www.micrium.com/products/rtos/ucos-ii_download.html
maganda yan kaso depende rin sa microcon mo kung naka port na kung gusto mo ikaw na lang mag port pero since bago ka pa yata sa RTOS mahihirapan ka, so hanap ka na lang ng mga micro con na na nakaport... alam ko marami sa atmel, sa Zilog wala yata...
di pala 'to pwede sa PIC16 series..  :'( pic16lf73 lang ang gamit ko..  :'(
anong pala ibig sabihin ng naka-"port" ?  ???
« Reply #21 on: April 04, 2008, 03:56:29 PM »
"port" - move from one system to another...example originally written for PIC18, pag linipat sa PIC16, "port" yun...
or kung program sa Linux, linipat sa Windows, "port" din yun...
Offline celdricg
    • http://www.bobongbooks.com/
« Reply #22 on: April 04, 2008, 07:36:46 PM »
baka meron browse mo sa site nila or i-google mo
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #23 on: April 04, 2008, 08:46:41 PM »
Use the CCP peripheral.
-Clear the TRIS of the CCPx output.
-Set bit3 and bit2 of CCPxCON to high and PWM mode will run.
-Set PR2 for the period
-Set CCPRxL + CCPxCONbits 5 and 4 as the duty cycle.
-Turn on Timer2
buti na lang may section ng PWM settings sa Project Wizard ng CCS C.. ayos.. :D
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #24 on: April 04, 2008, 09:52:24 PM »
gamit ka nalang ng hitech c kasi mas lalong maiintidihan ang pic hardware habang nagacode ka. Medyo mahirap nga sa simula lang pero you understand deeper, which is important.
ok rin siguro ito. Matestingan ko rin ito balang later. Marami magagandang features i like it  :D
Thanx for sharing
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #25 on: April 04, 2008, 10:01:05 PM »
nakakawalang-gana pag di ko maintindihan ang proces,
lalo na kung magpapalit pa ako ng compiler,
kaya CCS C lang muna ako.. ahihihihi  :D
meron rin ngang RTOS ang CCS, di ko lang alam kung paano gamitin..  :(
« Reply #26 on: April 04, 2008, 10:09:16 PM »
medyo nakakarelate ako kasi dati ayaw ko din magpalit ng compiler. but nung lumipat ako ng ibang compiler,wala yung mga functions na nakasanayan ko kaya napilitan akong intindihin ang mga bagay bagay ;D kaya ngayon nakakailang palit ng ako ng compiler, as much as possible di ko ginagamit ang mga hardware peripheral functions kundi yung mga normal functions tulad ng printf,sprintf etc
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #27 on: April 05, 2008, 01:10:26 PM »
nakakainis.. mabilis ang andar ng minibot ko..  >:(
sa bilis nya, babangga muna sya bago madetect yung obstacle!..  waaaa :'(
« Reply #28 on: April 05, 2008, 01:11:47 PM »
at least nadetect nya ;D ;D
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #29 on: April 05, 2008, 01:13:56 PM »
palitan ko na kaya specs ng minibot ko..
hindi na obstacle-avoiding, obstacle-crashing mobot na!..  :'(
« Reply #30 on: April 05, 2008, 01:18:48 PM »
ganyan talaga...hindi pa perfect sa una... :)
yung mobot ko dati pag naka-detect ng obstacle, nahihilo... ;D
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #31 on: April 05, 2008, 01:22:59 PM »
ok lang sana bumangga basta makakabalik pa,
kaso walang reverse direction ang motors nya, kaya wala rin syang backward movement..  :'(
Offline paranz
« Reply #32 on: April 05, 2008, 01:30:33 PM »
If maliit lang current ng motor (< 20mA), pwede naman siguro i-connect diretso sa PIC pins para ma-reverse ang motor. Then, cross your fingers na hindi maapektuhan ang PIC sa noise ng motor  ;D
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #33 on: April 05, 2008, 01:34:54 PM »
sinukat ko dati yug steady current ng motor @ 3V, mas mataas sya compared dun sa rated sink/source ng pins ng pic..
ano pa kaya kung switching na yung motor drive..  kaya di ko na dinirekta.. :'(
« Reply #34 on: April 05, 2008, 01:39:34 PM »
pwede gumawa ng h-bridge na 4 npn transistors (2 pnp + 2 npn kung mas mataas sa 5V yung motor)...lalaki nga lang yung mobot mo...
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #35 on: April 05, 2008, 01:45:16 PM »
3V lang kasi ang supply ng motor..  :'(
kahit yung pinagayahan ko ng hardware ng motor, 1 npn lang ang ginamit..
http://elm-chan.org/works/ltc/report.html
« Reply #36 on: April 05, 2008, 01:51:18 PM »
hmmm...kung kailangan talaga umataras at hindi pwede h-bridge, pwede dagdag ng motor sa kabilang side ng gulong for reverse...dagdag hardware nga lang...
nakita ko rin dati yang site na yan...binalak ko ring gumawa pero na-arbor ng ibang tao yung mga vibrator ko ng cellphone kaya hindi na natuloy...
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #37 on: April 05, 2008, 01:55:34 PM »
hindi rin pwede 'to..  :(
lagyan ko na lang kaya ng parang spring para mag-bounce sya ng kaunti,
then may space na sya para makaliko.. ahihihi  :D
« Reply #38 on: April 05, 2008, 03:42:59 PM »
ah nadidikit na sa pader... ;D
yung unang mobot ko, may bumper na may spring...ang purpose talaga nun para wag mabasag ng mabasag yung PCB pag nabangga...pero useful naman dahil nakaka-maneuver kahit napunta sa sulok...
