Author Topic: Konzert 502A Help?  (Read 2550 times)
Offline sabati
Konzert 502A Help?
« on: May 09, 2010, 09:52:31 AM »
may problem po ako sa konzert 502a ngsstop siya parang yung ngjujump CD dahil ba overloaded siya? kasi 2pcs 15" targa 500w 4ohms subwoofer for base & 2pcs targa 12" 400w 8 ohms instrumental and 2pcs dai 1chi 200w 8 ohms horn tweeter gamit ko..
need ko ba palitan ng power amp? if yes po any idea po magkano power amp kayang idrive speaker ko..
any suggestion guys..thanks a lot..
Konzert 502A Help?
Offline sabati
Re: Konzert 502A Help?
« Reply #1 on: May 09, 2010, 03:40:59 PM »
naitry po yung 1 15" and 1 12" and 1 tweeter po very smooth po yung tunog and wlang naging problem so overload nga po cguro...
may wiring techniques para di maoverload? cnsya na po newbie talaga ako..thanks
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #2 on: May 09, 2010, 04:01:33 PM »
grabe naman load mo sir
mas maganda kung dalwang 502 gagamitin mo
ung isa para sa bass at yng isa ay para sa instrumental at horn tweeter
WootsPC2 Videos  Woots Page
Offline sabati
« Reply #3 on: May 09, 2010, 04:07:52 PM »
any idea po magkano power amp ibebenta ko nalang konzert 502a ko kasi balak ko pa mgdadag ng speaker soon..
Offline ion0827
« Reply #4 on: October 11, 2010, 05:33:44 AM »
sir woots, up ko lng ha...
loaded na kamo pag ganun yun set up..
panu pala pag sa videoke machine..
2x 12" subs
2x 12" woofer
2x horn type tweets
2x 5" midrange
2x 3" cone type tweets
di overload narin yan
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #5 on: October 11, 2010, 09:16:45 AM »
^tutunog yan kaso matatalo ung woofer pro depende kung anung woofer ang ginamit mo
mas fino ang tunog nung 3" na tweeter. i-suggest na parehong sub ang gamitin mo, ung
dual impedance ;D
Offline abeTIR
  • Pogi/Ganda Points: 96
  • the show must go on...
« Reply #6 on: May 30, 2011, 09:58:53 AM »
Japeyk 502A Konzert... :o
kahapon me nagpaayos nito sa akin 8 output pero 4 na dummy ;D...matanong ko lang mga master nakita ko kasi ang component placement nito puede atang i-utilize ito na magtrabaho lahat ng outputs...sa nakikita ko ito yata ang mga critical points na dapat mabago [hula-hula lang po ;D]
Drivers
q2,q30 = D669a
q8,q15 = B649a
r3,r31,r65,r109 = 100 ohms [limiting resistor to collector of pre-driver C9014 -q9 & q25]
z3,z4,z5,z6 = 27v zener 1w
32v-0-32v power trans
pacencia na wala kase akong schema nito..naisip ko lang kase panay daw nasisira ito :(
meron ba kayong schema nung original...tnks!
"The choice is in the eye of the beholder and in the ear of the listener"
- The Method of DePalma
Offline J@M
« Reply #7 on: May 30, 2011, 10:25:45 AM »
Drivers
q2,q30 = D669a
q8,q15 = B649a
Korek dami imitation ng Konzert nw..
Don't Give up
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #8 on: May 30, 2011, 10:34:58 AM »
Drivers
q2,q30 = D669a
q8,q15 = B649a
dapat c2073 at A940 yung driver :)
  • Pogi/Ganda Points: 315
« Reply #9 on: May 30, 2011, 11:24:39 AM »
korek c master :)
Offline abeTIR
« Reply #10 on: May 30, 2011, 02:02:21 PM »
master Woots29, ito lang ba ang naiiba sa orig?...sa mga resistors kaya..apat din ang source resistors nung japeyk at puede ring i-tap sa dalawang output pair...hindi ko lang alam kung merong ma-overload na pre-drivers [small to-92]...
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #11 on: May 30, 2011, 02:17:51 PM »
yup. may mga heatsink ung orig na drivers
sa to-92s ok lang yun
« Reply #12 on: May 30, 2011, 02:21:31 PM »
sa trafo din,yta??
Offline abeTIR
« Reply #13 on: May 30, 2011, 02:27:17 PM »
ok..hindi naman pala ganong critical...masubukan nga ;)
puntos sayo master!
sir hengilbert as is ata yung power trans...
A1941/C5198 pair kaya parin ata ng mga ito..
« Reply #14 on: May 30, 2011, 02:33:18 PM »
yep...
gumawa ako ng ampli na based on 502a
2SC5200 at 2SA1943 gamit ko
;D ;D di ko alam gumawa ng board
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #15 on: May 30, 2011, 02:38:04 PM »
sa trafo din,yta??
ung 502 nun may 3 ng relay
yep...
bawal yan sa amplifier nanununog ng tweeter yan :D
Offline abeTIR
« Reply #16 on: May 30, 2011, 02:39:51 PM »
wow nice naman...puede pa siguro pataasin ang VAS rail niyan sir...hi-power ata ang mga output na gamit mo ;)..meron ditong magaling mag-layout ng pcb..nakita ko yung mga gawa niya sa DIYAudio site ;D
« Reply #17 on: May 30, 2011, 02:42:10 PM »
;D ;D
personal use lang master..
malapit na masunog ;D
Offline abeTIR
« Reply #18 on: May 30, 2011, 02:43:00 PM »
ano ibig niyo sabihin master woots..3 trans ng relay o tatlo ang relay..para san yung isa pa?
« Reply #19 on: May 30, 2011, 02:43:54 PM »
heheh 1 pair plang yan...
ung traffo binaklas na toroidal galing sa isang amp.39-0-39VDC
