Author Topic: Sanyo 21" TV ST-21SE1  (Read 1112 times)
Offline luciferlove
« on: May 13, 2010, 02:30:52 PM »
Gandang araw po mga fellow techies.  Need help on Sanyo 21" color tv model ST-21SE1.  Sa unang buhay, mga dalawang oras tapos paikli ng paikli, malimit nang namamatay (shut off not standby).  Saan po kaya problema?  Maraming salamat po
Offline Triple_D
  • Pogi/Ganda Points: 164
Re: Sanyo 21" TV ST-21SE1
« Reply #1 on: May 13, 2010, 02:47:54 PM »
may picture and sound ba sa unang bukas?
Offline luciferlove
« Reply #2 on: May 13, 2010, 02:55:59 PM »
Ok po picture and sound, clear and steady.  After mga 2 oras, shut down po siya (no standby).  ty in advance
  • Pogi/Ganda Points: 771
« Reply #3 on: May 13, 2010, 02:58:50 PM »
coldsold at ecaps ang salarin dyan
resolder all bad contact replace small ecaps sa power supply at sa vertical section
Offline enriz622
  • Pogi/Ganda Points: 289
« Reply #4 on: May 13, 2010, 03:32:38 PM »
sa ts parang hinang or ecap nga po yan sa regulator area
Offline luciferlove
« Reply #5 on: May 13, 2010, 04:15:24 PM »
try ko po, thank you.  I'll report the turn out or result.
Offline sundyhips
  • Pogi/Ganda Points: 5
  • E=MC2
« Reply #6 on: May 13, 2010, 04:21:21 PM »
agreed ako ky sir pete
I believe that it's in our failures that we learn the most.
Offline luciferlove
« Reply #7 on: May 14, 2010, 08:22:19 AM »
Maraming salamat kay sir Pete at sa lahat hehe.  Under observation po ngayon yung tv, and so far so good po.  Ty very much again.
Offline moira
« Reply #8 on: May 17, 2010, 07:39:30 AM »
kumusta n pala to?anong nagawa mo dito sis?
« Reply #9 on: May 17, 2010, 09:16:13 AM »
magaling talaga yan si master  pete pagdating sa troubleshooting
gifted child talaga
ako nanaman lagi nalang ako ako ako.
bakit wala na sis ultra?
