Author Topic: Laser/Light Detector Circuit for digital counters  (Read 1802 times)
Offline webscatter
  • Pogi/Ganda Points: 14
    • Webscatter Online World-WOW
« on: May 16, 2010, 04:08:40 PM »
The Circuit:
http://j3eglobal.multiply.com/photos/hi-res/1M/6
I had a problem before in dealing with sensing or detecting a laser light. I made a counter project to count the number of persons entering a certain premise. The idea is to install from an entrance a laser transmitter and beamed opposite to the laser sensor. The count commences whenever a laser light is cut by a passerby. I successfully constructed the counter circuit.When i installed the prototype,i discovered a problem: counting jumps randomly. I suspected it is caused by the harmonic responses or glitches of the laser detector from the laser light.
I solved this problem by doing several trial and errors. Finally, the circuit i designed above solved the problem. The circuit consist of Photo-detector (in Photo-conductive configuration), the transistor driver and the one-shot multivibrator circuit.
The work of the Photo-detector circuit is to detect the laser light and reacts when there is an absence of light. When laser is cut, the transistor driver toggles from normally HIGH to momentarily LOW states. This triggers pin 2 of the 555 timer IC that produces an output of ONE-SHOT HIGH logic pulse. The LOGIC HIGH output can be determine by T=1.1RC. This output is sent to Clock In of the Counter...Every HIGHs or Pulse at the clock in, the Counter Counts...
This circuit works very well....I designed this last Oct132006... Any Q message me......
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
Re: Laser/Light Detector Circuit for digital counters
« Reply #1 on: May 16, 2010, 06:41:10 PM »
sana may picture nung prototype ;D
Offline webscatter
« Reply #2 on: May 17, 2010, 12:47:56 PM »
na-archive na kasi ang prototype....2006 pa ksi ito...
Schematic is 100% complete....
All u need to lng , beam the laser light ray sa photosensor nito....then ayos na....
tested n ito...
at naging best project ang nagawang nitong prototype that time....because of commercial viability...
Offline iyo karpo
  • Pogi/Ganda Points: 18
« Reply #3 on: May 27, 2010, 07:29:53 PM »
The Circuit:
Harmonic responses are also caused by induce emf from external electromagnetic sources. Try mo ung UTP (unshielded twisted pair).
Offline bankai
« Reply #4 on: June 14, 2010, 09:20:16 PM »
i'm also doing the same topic with you(infrared counter)
but the problem is me fail to do it...... so can u show me your circuit and let me do some research on it??? TQ
Offline webscatter
« Reply #5 on: June 14, 2010, 09:32:07 PM »
i was using this...
Offline bankai
« Reply #6 on: June 14, 2010, 09:42:14 PM »
can i know this one is receiver or transmitter??
Offline webscatter
« Reply #7 on: June 14, 2010, 09:43:56 PM »
RCVR....
TX is LASER LIGHT beamed to it....this is used for counters...100% works very well...
  • Pogi/Ganda Points: 924
« Reply #8 on: June 14, 2010, 10:21:39 PM »
i was using this...
naka configure xa as a monostable circuit/one-shot
Offline webscatter
« Reply #9 on: June 14, 2010, 10:23:38 PM »
MMV
