Author Topic: 555 timer + 74LS107 + 74LS08 = pushpull high voltage driver  (Read 2796 times)
Offline uranium235
  • Pogi/Ganda Points: 8
  • hobbyist, stupident
i just wanna share my little project on 555 timer  lalo na sa mga naghahanap ng high voltage transformer
driver.  ;D
it operates on 12-30V. estimated output is 4 to 6kV gamit ko ung transformer sa powerpack ng photocopier iron core type
ginamit ko na lng ung clay to take the pics of the arc mahirap na mahawakan ung wire  ;D
gamit kong power transistor dito is MJE3055 NPN transistor pwede rin power MOSFETs heat sink is needed
heres the simulation in proteus ;)
the diagram  ;)
if any question just feel free to ask  ;D ;D ;D
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
Re: 555 timer + 74LS107 + 74LS08 = pushpull high voltage driver
« Reply #1 on: May 19, 2010, 10:46:41 PM »
nkaka baog yan ;D
Offline nucleus
« Reply #2 on: May 19, 2010, 11:21:54 PM »
yung IR2152/IR2153 *IR2153 nakabili ako sa newport ay pwede rin dito sa cicuit nito :D based din sya sa LM555 pero dalawa na yung output nya pangdrive ng transistor ;)
Offline uranium235
« Reply #3 on: May 20, 2010, 12:56:35 AM »
nkaka baog yan ;D
depende na un sa gagamit kung masyado siyang pabaya  ;D ;D
[/quote]
yup base sa datasheet nun mukang parehas nga sila ng 555 timer ung ckt sa taas pwede rin siya iconfigure as half bridge or H-bridge pero hindi ko pa nasusubukan. ung sa output nung ckt pwede mo gamitin lahat ng gates ng 74LS08  :D
Offline Mhavskie
  • Pogi/Ganda Points: 77
  • NeverShoutNever!
« Reply #4 on: May 20, 2010, 03:36:24 AM »
Saan mo naman yan gagamitin sir TS, ako may ckt din ng HV nakatambak lang sa ngayon.
Offline rgv101
  • one man crew
« Reply #5 on: May 20, 2010, 08:39:46 AM »
^ pede yan pampatay ng kulugo  ;D
Offline uranium235
« Reply #6 on: May 20, 2010, 01:28:53 PM »
balak ko gumawa ng maliit na N2 TEA LASER pwede rin pang test ng diy HV caps  ;D
Offline nucleus
« Reply #7 on: May 20, 2010, 10:45:17 PM »
tested ko na sya sa high voltage h bridge 300VDC :D
Offline uranium235
« Reply #8 on: May 23, 2010, 04:09:59 PM »
ganun ba pero in comparison with IR2153 and my ckt above mas ok gamit ung IR2153 isang IC na lang kasi sya at designed sa to operate at higher voltage mostly for SMPS
Offline SexyPaint
  • Pogi/Ganda Points: 25
« Reply #9 on: May 23, 2010, 05:09:12 PM »
diba parang driver din po yan ng mga bumbilya ng pang 12volts? gaya ng flourescent tube? ganda kc panuurin spark nyan e, yung sakin low voltage linagay ko sa loob ng bute, ganda ng spark sa loob, light blue din yun spark..
Offline uranium235
« Reply #10 on: May 23, 2010, 08:29:29 PM »
parang plasma globe ma ung tinutukoy mo?? kung ganun nga kelangan low pressure ung loob
Offline SexyPaint
« Reply #11 on: May 24, 2010, 08:09:21 AM »
opo sir parang ganuan...
« Reply #12 on: May 24, 2010, 12:12:06 PM »
i suggest argon if you want high pressure arcing using hv/hf supplies.
Offline SexyPaint
« Reply #13 on: May 24, 2010, 01:46:32 PM »
hihih uranium naging argon na........
« Reply #14 on: May 24, 2010, 02:10:06 PM »
^ i work with gtaw kaya may konting experience ako with argon.
at the same time malalaki ang plasma globes 3" to 2' Dia. kaya argon ang nilalagay na gas sa loob.
if low pressure or vacuum ang sa loob nang plasma globe. it poses a danger of implosion. parang CRT tubes.
back to argon. if you want ambient/high pressure arcs get argon.
Offline uranium235
« Reply #15 on: May 24, 2010, 06:26:17 PM »
speaking of gases and HV arcs pwede mo subukan ung iba't ibang type ng noble gase for colored arc  ;D like ung argon kasi gamit as shielding gas for gtaw pwede rin for normal pressure confined sa loob ng globe
about naman ung low pressure hindi naman kelangan na sobrang baba or near vacuum ung pressure ung tama lang na magkakaroon ng arc discharge sa loob i consider na rin natin ung gagamiting glass globe  ;D
Offline sirjon
  • Pogi/Ganda Points: 127
« Reply #16 on: May 24, 2010, 06:59:17 PM »
Pwede kayang gamitin as crt rejuvinator yan o dapat mas mababa konti ang hi-vo?
Offline ekajara_josh
« Reply #17 on: May 24, 2010, 07:13:09 PM »
Sir, ask lang ako...is it dangerous ba?kc 4kV-6kV nya...naka2patay ba yan?la lang...ilan ung output current nyan sir?
tnx...
Offline uranium235
« Reply #18 on: May 24, 2010, 08:34:50 PM »
tnx...
medyo delikado lalo na accidentally na nahawkan mo ung both terminal with both hands hakit ung isang terminal mararamdaman mo na ung daloy nang kurente sa tingin ko may may posibility na makamatay kung hahawakan ng matagal sa magkabilang terminal idagdag mo pa kung yung hahawak ay may sakit sa puso
regarding sa current nsa 5-6 micro amp ata lang ung output base na rin sa pinanggalingan ng trasnformer ;D
Offline Mhavskie
  • NeverShoutNever!
« Reply #19 on: May 24, 2010, 11:17:08 PM »
DiY, stun gun, ayos na din yun, zvs mazilli driver ang meron ako dito.
