Author Topic: philips 21"flat  (Read 534 times)
Offline dar
  • Pogi/Ganda Points: 5
philips 21"flat
« on: May 20, 2010, 08:32:58 PM »
share q lang......Philips 21"flat....
Problem: naka check mode...white ang background...then service mode ang lumalabas....but normal sound...
Na solve q thru....
1.remove q eeprom...
2.nilagyan ko ng eeprom socket yung 8pin sa board
3.then turn on ang tv set...
4.lalabas ang service mode and ruster...meron ng picture,channel,display of volume and channel..
5.turn off using remote
6.while in off mode or standby,carefully load the eeprom to the socket...( be carefull in loading the eeprom,baka magkabaliktad)
7.then turn it on again... the unit should appear in normal mode....
8.kung lumabas ang service mode turn it off in remote and on it again... sana makatulong...tagal ko ng tanggap e2,,,cguro mga 3months na...nung friday lang nasolve.......thnks din sa mga idea ng mga sis....
philips 21"flat
Offline pEN DoTA
Re: philips 21"flat
« Reply #1 on: May 20, 2010, 08:35:04 PM »
thanks for sharing dar. pogi point sau. >:( >:( >:(
GOD LOVES YOU
Re: philips 21"flat
Offline tikneshan
Re: philips 21"flat
« Reply #2 on: May 20, 2010, 09:35:31 PM »
sir, anong chassis o model po ba?
"Ang ilog na maingay, asahan mong mababaw."
Re: philips 21"flat
Offline dar
Re: philips 21"flat
« Reply #3 on: May 21, 2010, 10:11:14 AM »
post q mamaya sir,
Re: philips 21"flat
Offline dar
Re: philips 21"flat
« Reply #4 on: May 21, 2010, 08:49:03 PM »
sir pacencya na,model 21pt nalang ang nababasa q,malabo n yung sulat ehhh
Re: philips 21"flat
