Author Topic: Voltage Regulator L78xx question po sa max Amp. delivered  (Read 1706 times)
Offline kenshee
  • Pogi/Ganda Points: 24
    • Project blogs
« on: May 25, 2010, 12:01:14 PM »
Mga Sir/Madam - question lang po.. what happens to L7805 regulator if the load asks for more current?
Like, sa DC motor po - if i stall the motor it it runs for like 900mA. what if there are two stalled DC motors? so (900mA x 2) = 1.8A.. the L7805 says it supplies 1.5A.
What would happen to the Regulator? or sa 2 motors? if the loads(motors) asks for more than the regulator is provided? or my concept is not right?
 i'm currently building an H-bridge and i'm stuck thinking and worrying on this part. :( pls help me po.
Click, like and drop by! :D
----> e-kendro.com <-----
Re: Voltage Regulator L78xx question po sa max Amp. delivered
« Reply #1 on: May 25, 2010, 12:10:06 PM »
babagsak ang voltage niya. 'yung TO220 size ba? kasi merong 78Lxx series na 500mA lang ang kaya.
« Reply #2 on: May 25, 2010, 12:10:18 PM »
pwede mo na tangalin yung voltage regulator. most H-bridges have separate voltages (Vdd and Vmotor). much like the L293d or any other h-bridges.
but minsan kailangan mo nang (buck) regulation like yung supply mo is 12 volts. then 5 volts yung motor. the L7805 can withstand really tough abuse. but PUT A HUGE HEATSINK! you want the heat out as soon as possible. walang problem yun kasi stall current is very small.
another thing is maglagay ka nang current regulation mo sa h-bridge.
Online pete
« Reply #3 on: May 25, 2010, 12:26:39 PM »
agree
pwede siguro dalawang 7805 hehehe
Offline kenshee
    • Project blogs
« Reply #4 on: May 25, 2010, 12:34:26 PM »
ok po thanks sir martin.
im thinking. the other way around po, to avoid heating the regulator, is it possible to make a parallel of 2 L7805 sir? (so they would add their supply currents)
ok, i'm off to test the heat sink approach. ty sir
Offline kenshee
    • Project blogs
« Reply #5 on: May 25, 2010, 12:35:50 PM »
agree
"siguro"? lol :D
« Reply #6 on: May 25, 2010, 12:39:55 PM »
ano ba voltage nung motor? at ano 'yung input voltage mo? pwede kang mag-parallel ng regulators pero kailangan mo maglagay ng resistor or ORing diode. at any one time, isa lang talaga ang nagbibigay ng full current, lilipat-lipat lang as the voltage drops from that regulator.
ano 'yung H-bridge mo? pwede kasing wala ng voltage regulation, i-regulate mo lang 'yung maximum current na kayang i-handle nung motor.
Online pete
« Reply #7 on: May 25, 2010, 12:42:02 PM »
Voltage regulator IC’s, with 3 pins, from LM7805 and LM7812 series are excellent for usage in voltage regulator circuits. If you need higher currents, up to 3 A, you must add a complementary transistor, T2 in this schematic. In a normal design, in case of a shortcircuit, the power dissipation can be very high. This problem can be solved using the voltage regulator
ito baka makatulong sayo
Offline kenshee
    • Project blogs
« Reply #8 on: May 25, 2010, 12:43:46 PM »
if i'm asking too much current sa output, what will happen sa input voltage ku? using a 9V battery - mabilis po bng maubos? hehe
cuz i tested a direct supply sa motor, which is (9V batt then DC motor)
ilang sec lang - i measure the battery, 7.99V nxa.. aun alarmed and worried again bka di mkaabot ng 1 lap e2ng line follower ko.
so, pairing it up with a regulator - will it lessen the consumption po b?
  • Pogi/Ganda Points: 203
« Reply #9 on: May 25, 2010, 12:50:30 PM »
line follower pala ang application :D, 4AA energizer kayang kaya 4 laps tapos H-bridge na transistor lang, no need sa regulator sa motor part, tapos separate battery sa MCU/logic circuit
Offline updated
  • Pogi/Ganda Points: 22
« Reply #10 on: May 25, 2010, 12:51:53 PM »
agree. or gamit ka rechargAble batt na 2700maH
"DO YOUR ORDINARY DUTIES EXTRAORDINARILY WELL."
« Reply #11 on: May 25, 2010, 01:24:05 PM »
kung ang aim mo pababain ang consumption, hihina rin torque ng motor. go for other batteries. and mas magandang gumamit ng PWM control para mas tipid sa battery.
Offline kenshee
    • Project blogs
« Reply #12 on: May 25, 2010, 01:30:29 PM »
Woah, gnun lang pla un? :D tpos lgay nlang agad ng 7805 pra sa MCU.
im planning the h-bridge plang.. I guess i know na what to do starting from here.
Thank you :)
« Reply #13 on: May 25, 2010, 01:33:10 PM »
yup ganun lang yun ;D
Offline kenshee
    • Project blogs
« Reply #14 on: May 25, 2010, 01:37:43 PM »
Thanks sir, i'll experiment with PWM later.This is my 1st line follower pa po kc. so i'll start with the basics muna :D
Offline kenshee
    • Project blogs
« Reply #15 on: May 25, 2010, 01:38:19 PM »
hehe lamat pogi point 4 u idol
Offline kenshee
    • Project blogs
« Reply #16 on: May 25, 2010, 01:39:03 PM »
bibili ako ng rechargable mamaya! haha
« Reply #17 on: May 25, 2010, 01:41:15 PM »
salamat sa points, you may also want to check my blog may na post ako doon na line follower with PWM pero using discrete components lang no MCU :D
Offline kenshee
    • Project blogs
« Reply #18 on: May 25, 2010, 01:43:43 PM »
Bookmarked! thanks
Offline glutnix_neo
« Reply #19 on: May 25, 2010, 04:10:32 PM »
isa pang dapat tandaan, dapat may heatsink ang 78xx mo if you want to draw upto its rated output.
