Author Topic: sony trinitron kv-21gmr1mkII  (Read 819 times)
Offline alipin
« on: May 26, 2010, 03:32:29 PM »
mga masters, need your help on this sony trinitron, dead set sya. pulled out Hout 2sD1878 (shorted), replaced with c4927. sinubukan kng i switch on at nag ON sya (TV) pero saglit lng sabay dahil na busted nnman. any suggestions mga master......
  • Pogi/Ganda Points: 776
Re: sony trinitron kv-21gmr1mkII
« Reply #1 on: May 26, 2010, 04:27:03 PM »
Offline alipin
« Reply #2 on: May 26, 2010, 05:08:38 PM »
sir pete, iba nga ung value ng dalawa. meron kcing ngmagaling dto samin. eh superior ko sya kaya sinalpak ko para makita nya kayabangan nya....
Offline nucleus
« Reply #3 on: May 27, 2010, 01:11:37 AM »
mas mataas ang specs ng C4927 kaysa sa D1878 *based sa original datasheet from http://www.alldatasheet.com may problema pa yung tv nyo
Offline gie62
  • Pogi/Ganda Points: 56
« Reply #4 on: May 27, 2010, 07:11:05 AM »
check mo fbt, baka sira.
Offline nucleus
« Reply #5 on: May 27, 2010, 02:08:45 PM »
^tama po, check narin baka mataas ang B+
Offline cyborg31
« Reply #6 on: June 20, 2010, 08:51:04 PM »
sir alipin,..kung n check mo n flyback ok cya,kung ung b+ normal naman tpos naninibak ng h-out,check mo ung 33k malapit s jungle ic,3x ko n naencounter change value un,from 33k to 39k,...sana makatulong
