Author Topic: Tony's Transformer DIY pics  (Read 48438 times)
  • Pogi/Ganda Points: 521
« on: May 27, 2010, 07:25:25 PM »
aikido preamp transformer diy:
Re: Tony's Transformer DIY pics
« Reply #1 on: May 27, 2010, 07:27:31 PM »
Online insomartin
« Reply #2 on: May 27, 2010, 07:29:06 PM »
asteeg. thanks for posting sir! comments naman per image. habang pwede pa i edit.
pero picture shows a thousand words.
nicely done sir. +1 po!  ;D ;D ;D
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
« Reply #3 on: May 27, 2010, 07:31:35 PM »
;D +1 din
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
« Reply #4 on: May 27, 2010, 07:36:35 PM »
+1 din :D
8051 stuff
« Reply #5 on: May 27, 2010, 07:44:36 PM »
thanks for you kind remarks, the transformer shown above used a 1 1/4 x 1 1/4 bobbin, it has 2 x 6.3volts @3amps low voltage  coils and a 150volt@350mA hv winding.....more to come...
Online insomartin
« Reply #6 on: May 27, 2010, 07:47:28 PM »
ngayon ko lang na google na tube preamp pla yung aikido preamp. asteeg
« Reply #7 on: May 27, 2010, 07:50:55 PM »
this one is for a tube amp plate and bias supply, it has a 1 1/2 inch center leg core stacked to 2inches:
« Reply #8 on: May 27, 2010, 07:55:17 PM »
ito naman yung pair od Dynaco clone output transformers A-470:
Offline pintac
  • e pluribus unum
« Reply #9 on: May 27, 2010, 08:05:45 PM »
Commercial quality na yang mga transformer nyo a, saan po makakabili niyang Bobbin na separate ang Winding sir?
« Reply #10 on: May 27, 2010, 08:09:17 PM »
yung bobbins galing sa DEECO...meron silang dual bay or dual section bobbins....madaling mag wind, pwedeng scramble winding....
yung black na core, Z11, equivalent sa M6, cost is P500 per kilo.....yung white cores galing sa DEECO, price is about 75 pesos per kilo..
Offline pintac
  • e pluribus unum
« Reply #11 on: May 27, 2010, 08:12:09 PM »
A okay, salamat sir.
Ano po yang Z11 cores o M6 yan po ba yong may silicon content?
« Reply #12 on: May 27, 2010, 08:18:10 PM »
Z11 is the asian counterpart of the M6 a good grade of silicon oriented steel, aka GOSS, grain oriented silicon steel...
Offline k0nzert_007
« Reply #13 on: May 27, 2010, 10:09:31 PM »
sir tony nagrrewind pala kau ng tranformer magkano parenwin sa enyo?
ano na pala cam na ginamit nyo kasi ang linaw ng pic?
Offline pintac
  • e pluribus unum
« Reply #14 on: May 27, 2010, 10:16:00 PM »
Iba po ba gamit na computation dyan sa GOSS cores sir? Pa PM o pakipost naman sir sa computation ng mga GOSS cores.
Offline voltaman_krc
  • Pogi/Ganda Points: 4
  • aruuuuu!
« Reply #15 on: May 27, 2010, 11:59:18 PM »
+1 din. :D
thanx for posting. :D
usb kayo ng usb.... "FLASH DRIVE" ang tawag dun.
« Reply #16 on: May 28, 2010, 07:32:24 AM »
paalis ako tonight, pntang russia....gamit ko yung n73 cellphone camera..
« Reply #17 on: May 28, 2010, 07:35:28 AM »
yung Z11 kaya ang mas mataas na flux density, kung sa DEECO irons gamit ko mga 0.9T, sa Z11 pwede hanggang 1.2tesla...kaya mas maliit ang built up traffo gamit ang Z11 kaysa sa Deeco iron na may parehas na voltamp rating...
« Reply #18 on: May 28, 2010, 07:47:40 AM »
+1 din. :D
thanks...
« Reply #19 on: May 28, 2010, 07:57:43 AM »
ito yung traffo na naka set-up para sa super leach, 2 1/4inches center leg stacked to 5 1/2inches...
