Author Topic: Tony's Transformer DIY pics  (Read 48396 times)
Re: Tony's Transformer DIY pics
« Reply #900 on: May 11, 2012, 11:30:31 PM »
OT:
Somebody might be interested dito..;D
  • Pogi/Ganda Points: 521
« Reply #901 on: May 12, 2012, 07:19:20 AM »
eto try ko solve yung question 3
1 3/4 x 3. stack, VA = (5.25 x 5.58)^2 = 858 volt-amperes
at 230v primary, Ip = 858/230 = 3.73 ampere
Np = 1750/2 = 333 turns, #19
turns per volt = 333/230 = 1.45
Secondary=50x1.45=72turns bifilar #15
tama ba master T?
ano kayo estimated magnetic wire kilo #19 in primary and kilo in #15 secondary?
TIA :)
5kg of 1 3/4 inch core stacks to about 2 inches, so you have a core area of 1.75 x 2 = 3.5 sq, inches, good for about 380watts.....
since you have a bigger window, you can use bigger wire size than you would for cores with smaller windows...
primary turns = 1750/3.5 = 500 turns, you can use #21
secondary turns =500(100/230) = 218 turns, so 2 coils of 109 turns each #17
kung 3 inches ang stack mo then you get more power....
you can use for purposes of estimating wire weight a mean length per turn = (1.75 + 3 +1.5)*2 = 12.5 inches
you length of primary then = 333 x 12.5 = 4162.5 or 347ft.....
from wire table, #19 has a weight factor of 256.5feet/lbs, so that the primary coil weight = 1.3lbs or 0.6kgs
the secondary coils with #15 has 104ft/lb so that you can estimate it yourself...
« Reply #902 on: May 12, 2012, 07:25:04 AM »
nice one kazam.....bicycle rim pwede rin gamitin...
OT:
Offline mund24
  • Pogi/Ganda Points: 37
  • Certified Boy'z
« Reply #903 on: May 12, 2012, 08:44:35 PM »
given the mean length= 12.5inches per turn
so for secondary total turns = 72 X 2= 144 turns
secondary total mean length = 12.5 X 144= 1800inches or 150ft
secondary total weight = 150ft/104ft/lb= 1.4lb or 0.64 kilograms
for standard or safe buy eto ang possible kilos
primary= 3/4 kilos-
secondary= 3/4 kilos
total= 1 1/2kilos of magnet wire
Master T, I like your idea na gusto mong ipukol sa aming mga newbies , even others that lack of knowledge and experience about this matter
a very good known  saying
“Give a man a fish; you have fed him for today. Teach a man to fish; and you have fed him for a lifetime"
your a good inspiration to us  ;)
+1 :)
« Reply #904 on: May 13, 2012, 06:53:54 AM »
thanks, when we estimate the copper, it is better that we overestimate, para maiwasan ang magdugtong sa kalagitnaan....or kaunting ikot na lang e naubusan pa ng wire...
Offline mund24
  • Certified Boy'z
« Reply #905 on: May 13, 2012, 12:27:41 PM »
I'll take note it , thanks ulit :)
« Reply #906 on: May 13, 2012, 12:56:29 PM »
sir tony may difference po ba pag may dugtong na sa winding?
« Reply #907 on: May 13, 2012, 01:01:12 PM »
bumubukol
« Reply #908 on: May 13, 2012, 01:02:28 PM »
aside from the inconvenience, extra work...
Offline TechG
« Reply #909 on: May 21, 2012, 11:11:34 PM »
Gusto ko din matuto mag DIY ng trafo.
katatapos mag back read from page 1
Voltage = no of turns
Amp = Wire Size.
paano kayo mag ccome up sa size ng Bobbins
example for seccondary na 12-0-12 5Amps
Offline AT ALPHA
  • Pogi/Ganda Points: 42
« Reply #910 on: May 22, 2012, 08:32:35 PM »
there is a transformer calculator which you can download from some sticky topic on this forum. try to download and input some sample requirement like what you need. from there you can ask questions herein or on that thread.
we will be glad to help you out don't worry, just make the first step and be sure to be detailed on your questions.
for starters the core area will require cross sectional area in cm2. you should know how to convert from inches to cm as core sizes available here are given in inches..
Offline noman75
  • Pogi/Ganda Points: 261
  • 09335154904 / 032-4848039
    • Here`s my blog....
« Reply #911 on: May 23, 2012, 11:08:15 PM »
@sir tony,,, meron kc trafo ng apli-speaker (china) sunog at tunaw na rin ang bobin... tanong ko lang ung bobin kc nito ay separate ung primary at sec,, pwede ko bang gamitin ung ordinary bobin na kasama na dun ung pri at sec? at pareho lang din ba ung turns ng primary at sa mga secondaries? TIA sir...
NoMaNz 4-ever
Believe in Yourself!!! Swallow foods you need but not be greedy, share what you have, who knows you`re teaching now the future MASTERS.....
Here`s my blog....
http://noman75.blogspot.com/
« Reply #912 on: May 24, 2012, 07:15:04 AM »
^pwede yan, pm mo si AT_Alpha baka meron syang dual bay bobbin....pero kung wala kang makuha pwede na rin yung single bay bobbin...
Offline noman75
« Reply #913 on: May 24, 2012, 08:11:16 AM »
^ salamat sir,, try ko PM si AT_Alpha... andito kc ako sa cebu,, sana meron din dual bay dito wala kc ako mahanap dito...
pa OT:
calling mga sis na taga cebu baka alam nyo bilihan ng dual bay bobin dito sa cebu aside sa ADVANCE wala din silang dual....
NoMaNz 4-ever
Here`s my blog....
  • Pogi/Ganda Points: 98
« Reply #914 on: May 24, 2012, 08:19:33 AM »
pa OT:
harmansons, acdc? pwede sad maghimo ;D
« Reply #915 on: May 24, 2012, 08:33:48 AM »
ano nga pala ang center leg at stack height ang hanap mo, baka meron sa deeco or me stock ako...
Offline AT ALPHA
« Reply #916 on: May 24, 2012, 09:47:44 AM »
a single bay bobbin can be converted into dual bay by placing some separator at the middle. just cut out a separator from a red fiber board (available at many transformer shops). before winding just place a make shift temporary spacer at one section in order for the first winding not to collapse and spoil your work. after winding the first section you can remove the spacer and proceed with the secondaries.
Offline airfield
« Reply #917 on: May 24, 2012, 09:52:20 AM »
Sir paano po pagcompute ng output transformer.Interesado din po kasi ako sa design ng tube amps.
Offline noman75
« Reply #918 on: May 24, 2012, 10:18:55 AM »
ito sir...
center leg = 7/8
stack to = 1 3/8
wow!!! magandang technic ito ahhh,,, salamat sa inyong dalawa... kape muna kayo
NoMaNz 4-ever
Here`s my blog....
Offline noman75
« Reply #919 on: May 24, 2012, 10:26:01 AM »
pa OT ulit:
salamat bai,,, na kayha sila ani? center leg = 7/8   stack to = 1 3/8
NoMaNz 4-ever
Here`s my blog....
