Author Topic: 20V to 12V power supply  (Read 1101 times)
Offline moira
« on: May 31, 2010, 08:01:46 PM »
pls. help po, may transformer ako sa bahay 20V ung secondary ng nlagyan ko ng 4,700uf/50V, nagiging 28V ung output. pano po magiging 12V?balak ko sana gawin using LM7812 pero duda ako kasi sa datasheet 14.5V to 27V lng ung operating voltage ng LM7812. pls advise. 8) 8)
Offline subzer0
  • Pogi/Ganda Points: 38
  • Garbage In Garbage Out.
Re: 20V to 12V power supply
« Reply #1 on: May 31, 2010, 08:07:39 PM »
zener diode ka muna mga 18V to 15V Vz nya tapos saka 7812 ok na yun basta more than 1A yung current ng Vz mo para mamaximize mo yung power para sa 7812.ilan ba current na gusto mo?pag di ka makakita ng malaking zener diode,try mo series pass transistor pero di na sa zener mapupunta yungcurrent kundi sa transistor.
Signing Off...
Offline starex
  • Pogi/Ganda Points: 5
« Reply #2 on: May 31, 2010, 08:31:53 PM »
2 pcs resistor in series connection will fix your problem sir
« Reply #3 on: May 31, 2010, 10:09:02 PM »
you could use, SMPS controller ICs... i use L4971 which could accept up to 58V.
Offline EMX_007
« Reply #4 on: May 31, 2010, 10:14:30 PM »
100R or 10R resistor series to input 0f  LM7812 ok na yun... gusto mo bigyan kita ng diagram?
« Reply #5 on: May 31, 2010, 10:24:33 PM »
MC3403A can also handle up to 40V.
Offline updated
  • Pogi/Ganda Points: 22
« Reply #6 on: June 01, 2010, 01:13:11 AM »
mga sir. try nyo yung lm2576hvt-adj. up to 60v kaya nya. 80 pesos lang yan sa newport. simple switcher 3A ang kaya.
Offline nucleus
« Reply #7 on: June 01, 2010, 01:34:41 AM »
agree tested ko na ito, at meron pala nito sa newport :D
Offline pEN DoTA
« Reply #8 on: June 01, 2010, 06:21:17 AM »
thanks sa lahat ng nagreply.
c remz po partner ko nuon ng shop. ako ang nagturo sa kanya dito sa forum. sometimes he use my account or pwede rin masasabi natin na isa lng kami dahil isa sya sa baguhang tech sa shop namin at isa lng ung pc namin. balak naming magtayo muli ng shop pero parang kulang pa kami ng tekniks even simple problem parang hindi pa pwede.
GOD LOVES YOU
Offline nucleus
« Reply #9 on: June 01, 2010, 06:27:26 AM »
thanks po sa lahat ng ngreply. nalilito ako kasi halos lahat ng advise nyo pwede. the next problem ko ngayun ay yung amperahe ng transfo. pano po ba malaman ang amperage ng transfo?pano pala e test to?
huli ang may multiple account :D
oh btw tungkool don sa tanong nyo sir, baka mas madali kung hindi yan toroidal sukatin nyo yung dimentions tapos calculate using transformer calculator para makuha yung power rating ng core tapos idivide sa output voltage
Offline pEN DoTA
« Reply #10 on: June 01, 2010, 06:42:55 AM »
hindi cya toroidal master. may sticker pala cya ang nakalagay SC-86-302  C4910. ano kaya ito?i'll try nlang sukatin master ung dimension ng transformer baka madali ko na to. :o
GOD LOVES YOU
Offline toasted siopao
  • Global Moderator
  • Pogi/Ganda Points: 107
    • TeknoBlogger
« Reply #11 on: June 01, 2010, 06:45:29 AM »
Nyahahahahah! Huling huli, umagang umaga ba naman kasi.
Offline nucleus
« Reply #12 on: June 01, 2010, 06:55:14 AM »
;D ;D
  • Pogi/Ganda Points: 771
« Reply #13 on: June 01, 2010, 08:05:59 AM »
hahaha patay dyan na si master glenjoy yari ang double account hehehe
