Author Topic: KaizerKillerEX Pre-Alpha Test=)  (Read 5258 times)
  • Pogi/Ganda Points: 414
Re: KaizerKillerEX Pre-Alpha Test=)
« Reply #40 on: June 14, 2011, 08:49:43 AM »
Ki sis ultra baka meron sya at si sis patatas. Yung copy ko kasi natabunan na.
« Reply #41 on: June 14, 2011, 08:55:38 AM »
check ko yung external drive ko kung may copy ako heheh, pero nagalaw ko na yun,malamang may bagong bugs yun :D nagalaw ko na kasi yun compare sa latest na nakapost dito :D
« Reply #42 on: June 14, 2011, 09:07:07 AM »
Ito subukan mo raw sis pete.
http://www.4shared.com/file/0pBPRivb/KaizerKillerEX.html
Sis gigz niupload ko muna sa 4bahagi.
« Reply #43 on: June 14, 2011, 02:57:43 PM »
Forum Download
Link below  ;D
V
V
V
V
« Reply #44 on: June 14, 2011, 02:58:56 PM »
ayos...point for you :D
impakta people lang kasi ang pedeng mag-attach :D kaya ayun :D ok yan =)
« Reply #45 on: June 14, 2011, 03:35:14 PM »
^ uy may nag dl na na isa! hehehe. thanks!
Offline de PatAtas
  • Pogi/Ganda Points: 330
  • ' The unbreakable
« Reply #46 on: June 14, 2011, 07:04:12 PM »
' bago ba to?
« Reply #47 on: June 14, 2011, 09:23:42 PM »
^Dati lang yan.
Offline de PatAtas
  • ' The unbreakable
« Reply #48 on: June 15, 2011, 07:23:30 PM »
' kala ko bagong version
Offline acer
  • Pogi/Ganda Points: 110
« Reply #49 on: October 06, 2011, 08:39:45 AM »
points para kay master Kaizer nasubukan ko narin gamitin kaizer killer.  proud to be pinoy
nevergive up
Offline grizzom
  • Walang malayong kulangot sa mahabang kuko.
« Reply #50 on: January 24, 2012, 03:53:56 PM »
Mga master pa upload naman ulit nito file na to na delete kc ung skin, tapus ung link d2 ayaw na. thanks
« Reply #51 on: January 24, 2012, 03:57:09 PM »
pagkauwe ko sa bahay hehehe
or try mo ito:
http://www.electronicslab.ph/forum/index.php?topic=17806.msg475436#msg475436
see attached file..
gusto ko ulet pagpatuloy ito pero di talaga mabakante...
Offline _basura_man()
  • Pogi/Ganda Points: 36
    • Learn robotics here.
« Reply #52 on: January 24, 2012, 04:29:23 PM »
buhay pa pala si kaizer killer...
-John
« Reply #53 on: January 24, 2012, 04:33:31 PM »
pinatay na ng LM Syndrome.....
:D
bubuhayin naten... abang lang kayo :D
  • Pogi/Ganda Points: 772
« Reply #54 on: January 24, 2012, 06:43:10 PM »
waiting.................
Offline grizzom
« Reply #55 on: January 25, 2012, 07:49:41 AM »
Master kaizer bakit ayaw gumana hindi parehas ng luma automatic scan na cia? thanks po ..
« Reply #56 on: January 25, 2012, 08:42:59 AM »
it would be better if you will read the whole thread for more info =)
Offline grizzom
« Reply #57 on: January 25, 2012, 11:10:44 AM »
Cge master  busy pa ulit sa work kaya d ko pa mabasa lahat sir. thanks again
« Reply #58 on: January 25, 2012, 11:12:56 AM »
sige... reviewin ko pa code ko dito, ay malamang maglinis ako dahil bulky pa code ko dito noon haha
Offline de PatAtas
  • ' The unbreakable
« Reply #59 on: January 26, 2012, 07:03:07 PM »
' copy ng alin... ba sis.?
