Author Topic: Plastic casing  (Read 865 times)
Offline OPTIMUS PRIME
  • Pogi/Ganda Points: 28
Plastic casing
« on: June 11, 2010, 11:20:08 PM »
Mga sis may nakita ako casing dito sa SG...try to see tig 2.5 SG dollar. Pero swak sa small modules to.
Try to see if may time I can bring some back home refund nyo na lang.
Halos pede sa Pickit2 ni Motion 55 at pickit2 ni Egizmo
Half the thickness sa Al**an na HC001
Dont worry about failures but worry about the chances you miss if you dont even try...........
Plastic casing
  • Pogi/Ganda Points: 321
Re: Plastic casing
« Reply #1 on: June 12, 2010, 12:30:26 AM »
count me in for one set! thanks! lagi na lang deeco at alexan enclusure gamit ko. at lease may conversation piece agad yung casing... "preh from sg yan!" hehehehe
Re: Plastic casing
Re: Plastic casing
« Reply #2 on: June 12, 2010, 12:59:05 AM »
chris,
baka may tinning plating solution jan, pang crimp tulad nung request ni gigz,
Re: Plastic casing
Offline carlsfootprints
Re: Plastic casing
« Reply #3 on: June 12, 2010, 12:59:32 AM »
pm sent sir chris :)
never saturate..
Re: Plastic casing
Re: Plastic casing
« Reply #4 on: June 12, 2010, 01:04:56 AM »
chris,
eto ung link nung LF thread ni gigz.. http://www.electronicslab.ph/forum/index.php?topic=17297.0
never saturate..
Re: Plastic casing
Re: Plastic casing
« Reply #5 on: June 12, 2010, 07:24:48 AM »
Sis MArtin tingnan ko ang solution kung meron. Yung crimper may nakita ako kahapon pero di ako sure if yun yung crimper na yun
Si 1901 noted
Offline Mayor Johnaray
  • Pogi/Ganda Points: 238
Re: Plastic casing
« Reply #6 on: June 14, 2010, 10:25:31 PM »
Count Me "IN" ;D ;D ;D
Note: pasalubong ;D
Re: Plastic casing
« Reply #7 on: June 16, 2010, 05:19:14 PM »
Note: pasalubong ;D
Naka uwi na ako ng magpost ka sister hehehehe
Re: Plastic casing
« Reply #8 on: June 16, 2010, 05:27:12 PM »
aww
ngayon ko lagn ito nabasa...
sis chris, may nakita kang crimper?
Re: Plastic casing
« Reply #9 on: June 16, 2010, 06:03:09 PM »
aww
Sis may nabili ako for myself proskit. Pero di ako sure kung ito need nyo ni Sis Martin kaya di ako nagdala pa. auto stripper at crimper in 1 (Professional series mga Php 900 equivalent)
Pero may nakuha ako na catalog ng complete proskit, fluke, sanwa at kyoritso. Tumatanggap naman ng online order yung nakausap ko dun. Kaya if ever magsabay na lang tayo if may bibilhin tayo dun.
Re: Plastic casing
« Reply #10 on: June 16, 2010, 06:09:20 PM »
proskit din yung sinasabe ni tita nothing.. sige, patingin na lang if ever=) thanks
punta ko sa parlor ni 'miss julie' sa sat=)
Offline vbignacio
  • Pogi/Ganda Points: 17
  • ROBOTIC ART_
Re: Plastic casing
« Reply #11 on: June 16, 2010, 07:41:42 PM »
Note: pasalubong ;D
;D ;D ;D
 Like us on Facebook!
Re: Plastic casing
« Reply #12 on: June 17, 2010, 09:04:16 PM »
Awwww ako na lang pupunta ng Singapore...
Re: Plastic casing
« Reply #13 on: June 18, 2010, 01:16:16 AM »
Ito yung nakuha ko na stripper and crimper...mukha mali nga di ata kaya ang wafer
http://www.proskit.com.tw/en/product/product_detail.asp?catid=6&itemid=8PK-371D#
Re: Plastic casing
