Author Topic: ePIC-KIT2 PIC USB Programmer and Debugger or eICD2 PIC In -circuit Programmer &  (Read 2419 times)
Offline e172ece
  • I do not fear computers. I fear the lack of them.
anu po ba yun the best na pic programmer between the two?
I am an Engineer
I serve mankind
by making dreams come true
pickit2.
Offline e172ece
ah i see pero kasing dali rin po ba gamitn like the e1dc2?
I am an Engineer
I serve mankind
^ absolutely. you have my word for it.
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
agree with sir martin :D at may sariling program ang pickit2 bukod sa MPlab so mas madali mag program using other compilers like proton or mikroc
8051 stuff
go for pickit2 din =)
hahah speaking of which.. may UART Tool ito, will try this pag may connector na ko.. argh... need to debug something..
Offline /
  • Pogi/Ganda Points: 317
mag iipon din ako nito para sa self study..
Offline tiktak
    • Tiktakx's Blog
mag iipon din ako nito para sa bf ko..
wow bait naman ;D ;D ;D
8051 stuff
Offline jaythecaesarean
pano po ung pagkabit ng mga wires mula sa ePickit2 papunta sa PIC? :)
Offline tiktak
    • Tiktakx's Blog
RB7 - PGD
RB6 - PGC
8051 stuff
Offline Mayalin22
  • Pogi/Ganda Points: 400
curious lang sis.. para saan yong resistor sa Vdd pin ng pic?
Offline tiktak
    • Tiktakx's Blog
bakit nga ba may resistor dun? di ko din alam sis baka 0 ohm :D
8051 stuff
Offline Mayalin22
Offline tiktak
    • Tiktakx's Blog
:D :D :D di ko napansin yung resistor nung napost ko haha para saan kaya yun?
8051 stuff
baka to provide a little isolation sa VDD ng supply circuit ng board at VDD ng PICKIT2. Pero kahit wala na, magwowowrk naman. kung lalagyan, siguro around 33ohms wont hurt.
to avoid confusion, eto nalang:
PGD and PGC varies depende sa chip. refer to the datasheet of the target PIC.
typically, RB7 and RB6 are PGD and PGC, respectively.
the resistors by the label "to application circuit" could be a value around 1kohms. this is to provide isolation from the circuit during programming. pero depende pa din sa application. siguro kakailanganin ang special na isolation circuit kapag sensitive.
Offline AClamp
RB7 - PGD
RB6 - PGC
Hello po, ang pag-connect ba nito sa pic ay nakamount na ba sa zif socket?
Kasi na-try namin na direct connect na sa pic with zif socket at nitong
ePIC-KIT2 PIC USB Programmer and Debugger ay hindi ma-detect ng PC ang device.
kapag gumamit tayo ng zif socket, di na yan tinatawag na ICSP. at kung sa zif socket, di mo na kailangang gumamit pa ng mga passive devices na nandyan sa diagram. direct connection yan.
Offline AirWire
Yung resistor sa Vdd, nilalagay lang yun para i-compensate / dissipate yung difference ng Vdd ng PICKIT2 at nung apps board. Kung ang Vdd is purely galing sa PICKIT2, maganda rin yun as a protection, malay mo, baka may mababang resistance across the power supply kapag patay yung source.... :)
Yung resistor in between the Pics Vdd pin at VDD eh typo or drawing error lang yan sa document.
Sa diagram na provided ni marcelino, wala ng nakalagay.
Hindi pwede magkaruon ng resistor in between ng Vdd pin ng pic at Vdd otherswise the i/o pins of the pic wont be able to supply current or drive any load or the pic itself wont be able to startup due to lack of current supply.
Kung hindi naman siya permanent at during icsp lang nakalagay, it defeats the very purpose of ICSP.
In addition, PICKIT2 could detect the presence of VDD on the target board. Should there be a power on the board, the VDD from PICKIT2 will automatically disconnect. It will try to supply the MCU so to provide a power during programming. However, in some case it may not successfully sustain power (max of 500mA lang ang current source ng USB port). Minsan kasi, madami nang nakakabit sa MCU. And this is also the reason for the Resistors by PGD and PGC on my posted diagram  - to provide a bit of isolation between the load the the PICKIT2.
So I say, mas maiging palaging may power yung board. Para  yung VPP nalang ang iintindihin ng PICKIT2.
