Author Topic: Binary Clock  (Read 1020 times)
Offline geneanthonytarca
  • 1 + 1 = 1
Binary Clock
« on: June 14, 2010, 12:46:51 AM »
i want to know kung may nakagawa na nito dito?
siguro sa MCU meron na, but this one uses logic gates etc.
Schematic Here:
http://www.instructables.com/files/deriv/FZQ/ILLU/FIM95W1L/FZQILLUFIM95W1L.LARGE.jpg
1x 32.768 KHz Crystal Osc.
1x 560pF
1x 22pF
1x 4060 14bit ripple cnt.
3x 4028 7bit ripple
2x 4082 Dual 4 input AND Gate
17x 470 ohm Resistor
3x  14.7k ohm Resistor
3x N.O Switch
1x N.C Switch
17x LEDs
mas ok ba kung gawin 555 IC yung crystal at 14 bit counter?
Avionics
Binary Clock
Re: Binary Clock
« Reply #1 on: June 14, 2010, 03:08:40 AM »
EPIC FAIL.
subukan mo lang to see the difference.
malas mo pa kung wala kang precise na frequency counter.
at kahit may frequency counter ka, temperature changes lang skewed na yung timing...
maghanap ka nang wall clock, alarm clock, wrist watch na may "quartz" may 32.768 khz crystal yun.
mag review kna nang binary to decimal mo ngayon pa lang. pero nice project. do it in logic gates. boring kapag mcu.
Re: Binary Clock
  • 1 + 1 = 1
Re: Binary Clock
« Reply #2 on: June 14, 2010, 10:40:55 AM »
i see..
may gusto lang akong itanong about dun sa diagram.
yung sa Part ng J1 di ko maintindihan kung anong component yun.
Avionics
Re: Binary Clock
  • Pogi/Ganda Points: 203
Re: Binary Clock
« Reply #3 on: June 14, 2010, 10:57:06 AM »
J1 malamang Jumper yan
Re: Binary Clock
  • 1 + 1 = 1
Re: Binary Clock
« Reply #4 on: June 14, 2010, 11:39:17 AM »
jumper papunta saan? may 1 , 2 at 3 pa kasi.
Avionics
Re: Binary Clock
Offline carlsfootprints
Re: Binary Clock
« Reply #5 on: June 14, 2010, 10:08:11 PM »
papuntang supply..
anong klaseng binary clock to? hehe.. clock na binary ang output?
never saturate..
  • 1 + 1 = 1
Re: Binary Clock
« Reply #6 on: June 15, 2010, 10:21:23 AM »
Yep binary ang output niya represented by LEDs which corresponds to a certain binary value to tell time.
1 2 4 8 16 etc.
Avionics
Re: Binary Clock
« Reply #7 on: June 15, 2010, 10:39:43 AM »
i see..
its a DC Jack Connector.. two pins were tied together in GND and the other one is for VCC
  • 1 + 1 = 1
Re: Binary Clock
« Reply #8 on: June 28, 2010, 01:11:28 AM »
planning to make this project ngayon linggo. okay din ba kumuha ng clock pulse through 60 hz ng ac line to get 1 hz pulses?
Avionics
Re: Binary Clock
