Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Academic Community and Professionals
Professional People
Overseas Filipino Workers
Magkano Rate ng Senior Design Engineer sa Taiwan?
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Magkano Rate ng Senior Design Engineer sa Taiwan? (Read 4014 times)
paoloramos
CR2032 Battery
Pogi/Ganda Points: 0
Re: Magkano Rate ng Senior Design Engineer sa Taiwan?
Reply #60 on:
March 25, 2012, 05:22:02 AM »
ok. i totally ignored the EM concept for this problem, heheh..
thanks po sa input and advice
Logged
Reply #60 on:
motion55
Technical People
Diesel Generator
Pogi/Ganda Points: 244
Gender:
Been at this longer than you've been alive.
Reply #61 on:
March 25, 2012, 06:27:10 AM »
@paoloramos
Don't be too discouraged at this time. R&D is a very broad field and although ideally you should, you don't have to know everything. As I said, ang fundamentals (like math, science and engineering) are very important. As you gain experience, you become more aware kung anung babantayin in your area of responsibility. Kung ang responsibility mo ay PCB design and passing electromagnetic compatibility tests, mas aware ka dyan. If you are on a different area, less so.
What is important is finding a path to your desired field. And becoming really good (an expert) in that specific area is most important. Kasi kung expert ka in your specific area, you can command a high pay. And that's what this thread is all about, di ba?
Logged
"Set your mind free!"
Reply #61 on:
paoloramos
CR2032 Battery
Reply #62 on:
March 25, 2012, 07:00:04 AM »
yup, agreed!
I guess I'll have to find a job first to gain experience and familiarize the different fields na pagpipilian
Logged
Reply #62 on:
tony
Technical People
Solar Power Satellite
Pogi/Ganda Points: 521
Gender:
leach amp afficionado
Reply #63 on:
March 25, 2012, 08:38:36 AM »
i always wanted to be in RnD, but i ended up getting jobs other than RnD.....
in the end, i was able to see my kids thru college and has some savings left and in a couple of years will be getting pensions, these should be enough to see me thru.....
i think all factors are to be taken in....what is it that you want?
if it is just money you want, trust me, it will not make you happy.....
Logged
http://www.diyaudio.com/forums/power-supplies/191730-tonys-latest-traffo-diy-build-10.html
Reply #63 on:
rdpzycho
Technical People
Pogi/Ganda Points: 632
Gender:
Respect Begets Respect
Reply #64 on:
March 25, 2012, 09:01:27 AM »
Quote from: paoloramos on March 25, 2012, 05:22:02 AM
actually, tungkol sa grounding 'yung tanong, in-elaborate ko lang 'yung discussion about the ideal world na meron pa ring EM.
kahit 'di ka pa rin decided kung ano gusto mo, mag-job hunt ka pa rin, you'll never know if in the end, gusto mo pala 'yung field ng mapupuntahan mong trabaho. honestly, ayaw ko sana pumasok doon sa first company ko dahil merong better choices, what's done is done, kaya nandito na rin ako, at nagustuhan ko rin ang Power Electronics dahil doon.
Logged
Reply #64 on:
bryanwizard30
CR2032 Battery
Reply #65 on:
July 09, 2012, 11:15:05 AM »
sama din po ako
Logged
Dandy
Lead Acid Battery
Pogi/Ganda Points: 31
Reply #66 on:
April 03, 2013, 08:43:23 PM »
@TS,
sa S4 ka na diba? Magkano Rate ng Senior Design Engineer diyan?
Logged
glutnix_neo
Technical People
Nuclear Reactor
Pogi/Ganda Points: 166
Gender:
A journey to a thousand lines begins w/ LED Blink
Reply #67 on:
April 03, 2013, 10:51:20 PM »
tama lang master Dandy, tama lang na umuwi na ko pinas, hehehe
seriously mas malaki kaysa sa taiwan pero malaki din gastos ang walang kasiguraduhan kasi di na welcome foreign workers dito.
Logged
Reply #67 on:
Print
Pages:
1
2
3
4
Go Up
« previous
next »
Professional People
