Author Topic: WESTRAK AMP NA 500 WATTS @ 8 OHMS LOAD  (Read 48773 times)
Offline Berlin C. Alcayde
  • Pogi/Ganda Points: 5
Re: WESTRAK AMP NA 500 WATTS @ 8 OHMS LOAD
« Reply #840 on: January 31, 2012, 11:42:16 AM »
Sir magkano bili mo sa pcb?
190 pesos ang 1 pc.
Offline geralma
« Reply #841 on: February 01, 2012, 05:17:29 AM »
Sir Tony,Okey n po ung westrak ko...nairaos ko n rin cya khit ordinary tools lng po mga gamit ko....Normal n po ht..Salamat mga sir..
Tanong ko lng ulit kung okey lang ba gawing 5.6k yung 15k resistor na naka series sa bias diode na nakalagay sa base coleector ng bias transistor 2N5551 SA WESTRAK AMPS?Salamat po...
  • Pogi/Ganda Points: 539
« Reply #842 on: February 01, 2012, 07:06:27 AM »
congrats, +1 for you....
Offline 1022jv
  • Pogi/Ganda Points: 25
« Reply #843 on: February 23, 2012, 01:20:30 AM »
Gusto ko lang mag tanong if this is  speaker (Paudio IMF-HP18s) is good for a westrak amp or should i choose crown jack hammer JH-181, TNT 1000 watts or live 18 pa-1000watts. Gusto ko lang malaman ang opinions nyo lalo na for PA and disco, Baka magsisi pa ako sa huli. Elco kit ang gamit ko ngayon pero try ko sana ang westrak. For now I want to try yung IMF from paudio. First time ko kasi mag buy ng 18inch speaker for sub purposes kahit two pcs lang muna.
Offline immong72
« Reply #844 on: March 05, 2012, 03:43:54 PM »
tanong ulit mga masters, dito po sa uprated westrak schem sa page 26 bakit po wala ung rec didode sa BC ng bias trans at bkit po ung 15k na resistor naging 4k7? nex proj ko po sana para sa 65-0-65ac transformer ko. thanks po ulit. .
« Reply #845 on: March 05, 2012, 05:31:10 PM »
400watts ba yan?
ampanget ng design
hahaha SUPALPAL! ;D
Offline danny
  • Pogi/Ganda Points: 324
« Reply #846 on: March 06, 2012, 03:14:33 AM »
ngayon ko lang napansin yun ah
grabe sa comment yun ah
danny
Offline jb1_amp
« Reply #847 on: March 19, 2012, 04:55:35 PM »
Mga sis my final na schema na kau ng westrak ang supply ay 65 0 65ac 20amp?
yung kayang kay jbmobile ok n kaya circuit non?
Offline kirk simone
  • Pogi/Ganda Points: 7
« Reply #848 on: May 05, 2012, 12:55:36 AM »
sana meron namang online buying/group buying at ipadala sa air21.
count me in sir 2pcs
shake it .....
« Reply #849 on: May 06, 2012, 06:26:24 PM »
Sir tony at sa iba matanong ko lang, what's the advantage of using triple darlington over the darlington?
« Reply #850 on: May 06, 2012, 07:49:50 PM »
with triple Darlington, your VAS will be loafing all the time...really depends on the drive requirements of the output stage
« Reply #851 on: May 06, 2012, 08:01:23 PM »
loafing? i really have no idea.. :)
« Reply #852 on: May 07, 2012, 06:37:47 AM »
what i mean is, your VAS will just be swinging voltage only, current delivery is very very small....
« Reply #853 on: May 07, 2012, 07:34:17 AM »
ahh i see :D +1 ulit
  • Pogi/Ganda Points: 414
« Reply #854 on: May 08, 2012, 10:54:50 PM »
Sana meron mag upload ng scanned copy ng PCB nito...;D
« Reply #855 on: May 09, 2012, 06:47:48 AM »
^ backread sir. :D
Offline 4XFOUR
  • Pogi/Ganda Points: 30
« Reply #856 on: June 19, 2012, 05:40:30 PM »
umaanghang mata ko sa kakabasa ng 43 pages heheheh.... may nagawa akong ampli dati 100watts gumana mga ilang araw pero nung nasunog ang resistor transistor nawalan na ako ng gana kasi wala ng pambili ng pyesa studyante pa lang kasi tapos wala rin mapagtanungan kung ano problema ano mali ano problema.... may natutunan din ako dito, kasi open yung mga expert dito, kungbaga pag may problema pwede agad itanong sa experto...
kudos to the masters.... sir tony, bongtech, johannah, at sa mga di namention na experto... saludo ako sa inyo... :)
3rd Island Epicenter
Officially Deployed
Offline 02hertz
« Reply #857 on: June 26, 2012, 08:51:26 PM »
mga sir, pwede pa po bang gawing 85 0 85 tpus ung traffo 20 amps ung supply ng westrak po??
sana po msgot nyo, newbie plang po ako ee :)
advnce tnx po^^
« Reply #858 on: June 26, 2012, 08:53:57 PM »
work on the original voltage first then proceed to your desired voltage.
nasagot na ung katanungan mo sa kabila :)
Offline danny
« Reply #859 on: June 27, 2012, 03:19:30 AM »
agree  ;D
danny
