Author Topic: PIC Based Timer  (Read 2393 times)
Offline BoyAlgoa
PIC Based Timer
« on: April 06, 2008, 02:06:40 PM »
Hi Guys,
ask ko lang po sana kung meron na ditong gumawa ng PIC-Based Timer (with 2 x w/ 7 segment). Gusto ko po sanang gumawa ng 2-digit Hour Timer. Ilalagay ko lang po sana as replacement sa Mechanical TImer ng Aircon ko, nasira na kasi eh...Please help me kung pano po sisimulan....Kailangan ko po ng Reset, Up/Down Functions....Salamat po
PIC Based Timer
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
Re: PIC Based Timer
« Reply #1 on: April 06, 2008, 02:09:17 PM »
ask lang po, do you have background sa PIC programming?
Re: PIC Based Timer
Re: PIC Based Timer
« Reply #2 on: April 06, 2008, 02:14:52 PM »
Hi Guys,
baka mas makamura ka kung bili ka na lang ng power-on delay na may built in timer.
Re: PIC Based Timer
  • Pogi/Ganda Points: 635
Re: PIC Based Timer
« Reply #3 on: April 06, 2008, 02:17:47 PM »
kilala ko gumagawa dito niyan... ;D
Re: PIC Based Timer
Re: PIC Based Timer
« Reply #4 on: April 06, 2008, 02:20:40 PM »
mukhang madami kang kilala dito ah ;D
Re: PIC Based Timer
Re: PIC Based Timer
« Reply #5 on: April 06, 2008, 02:27:04 PM »
hindi ko lang alam kung nandito sila sa forum...hehehe...
Offline Mentor Lee
  • Pogi/Ganda Points: 16
  • "Call to Me and I will answer you.....
Re: PIC Based Timer
« Reply #6 on: April 06, 2008, 02:34:01 PM »
I have done it once during my early days with PIC. I used mikroPascal & PIC16F628A with 4x 7S LED & 4 common anode driver transsistors + few buttons.  Now I have the same question as Paranz's: Do you have PIC background?  ??? ???
...and show you great and inscrutable things that you do not know "
--Hotline 333--
Offline BoyAlgoa
Re: PIC Based Timer
« Reply #7 on: April 06, 2008, 03:40:31 PM »
Basic PIC Software Routine lang po and some hardware functionalities...Ask ko lang po sana kung pano ko sisimulan....thanks
Offline paranz
Re: PIC Based Timer
« Reply #8 on: April 06, 2008, 03:51:41 PM »
make the hardware first. You may use a PIC16F84a with the 2 7-segment and maybe a 7-segment driver like 74LS47
Offline BoyAlgoa
Re: PIC Based Timer
« Reply #9 on: April 06, 2008, 04:39:46 PM »
San po kukunin ang clock nya? sa crystal lang po ba? bawat digit po sana ay hour counter....pano ko po kya un idedeclare sa pic basic?
Re: PIC Based Timer
« Reply #10 on: April 06, 2008, 04:43:04 PM »
pwede sa clock (using Timer), pwede ring sa AC line (like what some alarm clocks do)...
  • Pogi/Ganda Points: 414
Re: PIC Based Timer
« Reply #11 on: April 06, 2008, 04:50:40 PM »
I think this is what you're looking for?
http://www.interq.or.jp/japan/se-inoue/e_pic6_3.htm
RBT
Offline Mentor Lee
Re: PIC Based Timer
« Reply #12 on: April 06, 2008, 10:54:27 PM »
I recommend the use of timer register. The line frequency is not stable and will give big time drifts. Plus, you have to be dependent on the line - this will be a concern if you run on battery. If the cost doesn't concern you much at the moment, yes you can use external 7sd decoders but an 18pin PIC is enough for four digits.  ;)
--Hotline 333--
Re: PIC Based Timer
« Reply #13 on: April 06, 2008, 11:02:23 PM »
true sir...laging advance tuloy yung alarm clock dito sa kwarto namin... ;D
Offline Mentor Lee
Re: PIC Based Timer
« Reply #14 on: April 06, 2008, 11:15:27 PM »
Hindi ka nag-iisa,   :D yung alarm clock ko , SONY pa naman na may kasamang radio..naku after 3 days around 20 minutes ang drift - what a waste >:(
--Hotline 333--
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
Re: PIC Based Timer
« Reply #15 on: April 06, 2008, 11:21:19 PM »
ok na ang mga yan.. kesa naman sa di sila mag-alarm.. hehe  :D
Re: PIC Based Timer
« Reply #16 on: April 07, 2008, 11:59:05 AM »
if you're into precision timing go for xtal controlled or even oven stabilized time based generator...pero kung di naman critical timing application you can opt to a simpler one..don't complicate your life..
RBT
Offline BoyAlgoa
Re: PIC Based Timer
« Reply #17 on: April 07, 2008, 05:00:49 PM »
RBT
Bosing thanks ng marami, sige check ko and pag aralan na rin ung anatomy nya....
Offline gerisonic
Re: PIC Based Timer
« Reply #18 on: May 07, 2008, 01:35:08 AM »
Baka sa other country mo nabili yan at 50Hz ang reference frequency nila. Mabilis talaga ang takbo nyan if dito sa pinas 60Hz ang gamit natin.
Offline Mentor Lee
Re: PIC Based Timer
« Reply #19 on: May 07, 2008, 01:31:24 PM »
I bought that one in HongKong (50Hz) during one of my family's holidays. When I came back to Vietnam which is also 50Hz, ganyan na ang performance nya. My wife tried it there in Pnas, lo & behold, mas malaki ang drift - 2+ hours in one whole day  :D. Actually, sinauna siguro yung design nya. Na attract lang ako kasi nga SONY. Most of the digiclocks now are having standalone time chips. Lesson and lesson, kahit matanda na tayo, we still have to learn lessons ;)
--Hotline 333--
Re: PIC Based Timer
