Author Topic: PICMe Microcontroller Starter Kit from http://www.asti.dost.gov.ph  (Read 14919 times)
Offline nian
Re: PICMe Microcontroller Starter Kit from http://www.asti.dost.gov.ph
« Reply #100 on: February 13, 2010, 07:58:59 PM »
Hi sa lahat!
Nakabili rin ako ng PICME last January sa Alexan kasi interested ako sa I2C at SPI programming.  May problema lang ako... May nakasubok na ba sa inyo gamitin yung PICDSM sa Windows 7?  Natry ko na yung buong kit sa XP ok naman sya (as in fully-functional), pero sa Windows 7, nag-"Open port error" ako.  Ok naman yung rs232 port ko saka nakakaconnect yung Serial Monitor.  Express card gamit ko na RS232 port, pero tested ko na na working sya (using Ping-Pong loop-back test)
Ano pa kaya iba pwede gamitin na simulator kapalit ng PICDSM na puwede sa PICME?  Sana matulungan nyo rin ako.
Salamat!
"I'm not here, so am I in two places at the same time?"
Offline pochd
« Reply #101 on: May 20, 2010, 08:21:57 PM »
Is it ok to use solid wire to access the I/O pins? (directly inserting wire into dual function header socket)
Offline agimat
    • PHP Programmer . Python . Ruby . Manila . Philippines
« Reply #102 on: May 20, 2010, 11:11:55 PM »
Hi sa lahat!
Salamat!
Gamit ko yang PICME sa Windows 7, wala naman issues whatsoever for me.
rlachenal.com - PHP Programmer . Python . Ruby . Manila . Philippines
loadmango.com  - The juiciest prepaid card deals online
Offline agimat
« Reply #103 on: May 20, 2010, 11:15:57 PM »
Ok lang naman. Ingat lang maputol and maiwan sa socket yung piraso at medyo mahirap minsan alisin.
Offline pochd
« Reply #104 on: May 21, 2010, 01:11:17 PM »
If it is not ideal to insert solid wire into the dual function pins, what should you use instead?
Offline OPTIMUS PRIME
  • Pogi/Ganda Points: 28
« Reply #105 on: May 21, 2010, 09:08:34 PM »
ok lang sabi nga mag insert wag lang maliit na soild wire para di madali maputol.
Offline marleona
« Reply #106 on: May 22, 2010, 05:50:53 PM »
Pwede po ba makahingi ng installer ng PICMe? Nawala ko kasi ung cd or di ko mahanap. hehehe Thanks!
It is not the answer that enlightens, but the question.
Don't hesitate to ask question.
If you don't ask, you don't get.
Offline agimat
« Reply #107 on: May 22, 2010, 07:35:13 PM »
Sure. The included CCS trial version is very old though, so hindi ko na sinama sa archive. Download ka na na
lang ng mas recent from the CCS site if you want to use that compiler.
http://dl.dropbox.com/u/11787/Ron/pm.rar
Offline marleona
« Reply #108 on: June 05, 2010, 03:46:23 AM »
bakit no bootloader found.... help, di ako makaprogram hehehe tnx!
Offline agimat
« Reply #109 on: June 09, 2010, 11:59:54 AM »
Kung USB serial, minsan nag wa wander yung port setting. Make sure na tama.
Any chance you overwrote your bootloader? Happened to me not too long ago.
Di ko mahanap kung ano yung original bootloader (anyone here know kung ano) na gamit ng PICMe so
I installed tinybldr instead which works well enough.
As it goes, I found this local blogger na may PICme info on his site pero medyo matamlay
sa detalye ang postings so I went and asked kung ano yung name ng bootloader na ginamit
nya and where to find it --- I saw his reply this morning -- he sent me a Paypal link :D
Kelangan muna daw mag *donate before he can send me any info. haha
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
« Reply #110 on: June 09, 2010, 12:15:47 PM »
^parang nakita ko din yang local blogger na yan :D pero parang may conflict sa sinabi nya sa about sa kanya :D, well tingin ko OK din yung tiny bootloader at least maliit lang kakaining space
8051 stuff
Offline agimat
« Reply #111 on: June 09, 2010, 12:23:31 PM »
Yup. hassle lang sa tinybldr na you have to keep the reset button on-hold while flashing.
Tinanong ko yung blogger kung magkano minimum donation tsaka kung yung name ba ng bootloader e for sale rin :) inaantay ko pa sagot.
Offline marleona
« Reply #112 on: June 09, 2010, 01:23:25 PM »
waaaaaa paano un??? bakit ba naman kasi nawala un eh.
Offline zephyr2009
« Reply #113 on: September 02, 2010, 11:17:50 PM »
Meron po kayo link kung saan pwede ko po idownload yung PICDSMv1.9.exe?
yung nasa installation cd po nitong PICMe?
Please help me po..
or meron po ba kayong alam na software na pwedeng magburn ng hex file sa PICMe?
Offline marleona
« Reply #114 on: September 03, 2010, 03:52:01 AM »
back read ka lang dito. meron akong nakuha dito dati eh. kailan mo binili yan??? dapat ng epickit2 ka na lang. sayang pera ko dito eh.
Offline eteny
« Reply #115 on: July 30, 2011, 12:07:52 PM »
Hi! I was wondering if may nakagamit na ba nung PICME na binibenta sa Alexan? Gusto ko sana subukan. I have bought one, but then I need help installing it, since I do not have any experience with PIC. Thanks!
If anyone would be willing to help, please send an email to etenyworks@yahoo.com. I would really appreciate it. Thanks!
