Author Topic: patulong po sa tone control  (Read 2733 times)
Offline badalicious
« on: July 09, 2010, 09:22:05 AM »
sa mga masters naitn jan, patulong naman po sa aking first built na tone control.
ito diagram nia"
[/URL]
Uploaded with ImageShack.us[/img]
Problem: walang bass tone, tapos medyo malabo ung sound,parang may sumasagitsit na kasama. Pero pag tinouch ko ung R2-47K umo-ok ung tunog with 1-2 seconds tapos balik ulit sa pangit.
ano po kaya magandang gawin dito. sayang namna kc ung effort,time at money kung di maaus.
tnx po in advance. alam ko semple lang to sainu.
POWER!
Offline badalicious
Re: patulong po sa tone control
« Reply #1 on: July 09, 2010, 09:26:05 AM »
ay di lumabas ung picture.first time ko din post ng may pics .ito cguro ok na.iba n kc ung proces n pinost ng isang member d2:
[/URL]</noscript>[/img]
[/URL]
Offline badalicious
« Reply #2 on: July 09, 2010, 09:29:02 AM »
wala pa din ito cguro meron n.
Offline badalicious
« Reply #3 on: July 09, 2010, 09:29:56 AM »
Offline badalicious
« Reply #4 on: July 09, 2010, 09:30:40 AM »
hay salamat dumikit din
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #5 on: July 09, 2010, 09:43:44 AM »
tANong!
anung ginamit mo sa c1, electrolytic o mylar?
may problem ka sa biasing sa preamp section
pwede mo namang i-bypass yan eh direkta mo ung signal sa
sa + ng C4 kung masyadong mataas ang gain ;D
WootsPC2 Videos  Woots Page
Offline badalicious
« Reply #6 on: July 09, 2010, 09:45:19 AM »
elctrolytic po
Offline badalicious
« Reply #7 on: July 09, 2010, 09:49:01 AM »
directa po from R2 to + ng C4 tama p po ba?tsaka maaus kaya siya kung palitan ko ng mylar?
Offline Born2BeWired
  • Pogi/Ganda Points: 168
    • e-Gizmo Mechatronix Central
« Reply #8 on: July 09, 2010, 09:53:38 AM »
ito diagram nia"
[/URL]
POWER!
Another classic symptom of parasitic oscillation. This is usually layout related. We can help you further if you show your layout.
A quick fix that may work is to reduce the bandwidth of your transistor amps. This can be done by increasing the value of capacitor C2 and C12. You can try using 100pF-470pF.
Be reminded that you should use linear type potentiometer for VR1,VR2 and VR4. Linear type pots are denoted with 'B' suffix (e.g. 100KB, 5KB) VR3 should be audio tapered ( identified with 'A' suffix e.g. 100KA, 50KA).
Finally, using a single pot for VR4 is a bad idea. You can't get a stereo separation better than 30dB with a single pot because it will allow excessive crosstalk to bleed through each channel. Use a dual pot instead.
Offline danny
  • Pogi/Ganda Points: 323
« Reply #9 on: July 09, 2010, 09:59:47 AM »
parang nakita ko na ito sa libro ah
nde ba ito yung kay pagirigan
yung pulang book??  ???
danny
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #10 on: July 09, 2010, 10:10:35 AM »
^may tama ka sir ;D
Offline danny
« Reply #11 on: July 09, 2010, 10:16:11 AM »
 ;D ;D ;D
danny
Offline badalicious
« Reply #12 on: July 09, 2010, 10:17:12 AM »
tANong!
nawala po ung sound
Offline badalicious
« Reply #13 on: July 09, 2010, 10:24:05 AM »
mono po amp ko.kaya tatlo lang pot.ang label nung tatlo B100k.so ung isa palitan ko ng A.
ano po kaya ung exact value n pwedng capacitor
Offline badalicious
« Reply #14 on: July 09, 2010, 10:26:31 AM »
i2 po ung lay out n ginamit ko kung tamo pagintinidi ko
Offline badalicious
« Reply #15 on: July 09, 2010, 10:31:19 AM »
wala po kayang magiging problem dun sa pcb ko kc scatch tape lang ginimit ko sa etching.ung ibang line naputol pero may jamper naman.connected namna lahat,
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #16 on: July 09, 2010, 11:01:10 AM »
sundin mo muna ung payo ni sir born about the capacitor para malimit ung freq
den kung ganun pa rin we need to investigatre whats really goin on
Offline badalicious
« Reply #17 on: July 09, 2010, 11:05:10 AM »
cg po bili muna ako
Offline RaffT
  • Pogi/Ganda Points: 103
  • more on R-n-D
    • MY Bots
« Reply #18 on: July 09, 2010, 11:19:26 AM »
 recheck mo lang ginawa mo... keep your wirings as short as can be possible...
« Reply #19 on: July 10, 2010, 03:38:28 AM »
Malamang sa pcb mo ang problema at sa soldering, try to resolder all your connections or gawa ka na lang ng bagong pcb.
