Another classic symptom of parasitic oscillation. This is usually layout related. We can help you further if you show your layout.A quick fix that may work is to reduce the bandwidth of your transistor amps. This can be done by increasing the value of capacitor C2 and C12. You can try using 100pF-470pF.Be reminded that you should use linear type potentiometer for VR1,VR2 and VR4. Linear type pots are denoted with 'B' suffix (e.g. 100KB, 5KB) VR3 should be audio tapered ( identified with 'A' suffix e.g. 100KA, 50KA). Finally, using a single pot for VR4 is a bad idea. You can't get a stereo separation better than 30dB with a single pot because it will allow excessive crosstalk to bleed through each channel. Use a dual pot instead.
parang nakita ko na ito sa libro ahnde ba ito yung kay pagirigan yung pulang book??
mga master san po kya ako makakabili ng murang knockout puncher kailangan ko po ng sizes n 1/2" inch to 2" inches......tnx po in advance
tapos bakit pgtinatouch ko ung terminals na malapit sa t1 may nasasagap sa radio signal di ko sure kung am or fm?any idea?
itry ko muna ilipat sa maaus na pcb
pinalitan ko na po ng 470 pf.ganun parin. tapos bakit pgtinatouch ko ung terminals na malapit sa t1 may nasasagap sa radio signal di ko sure kung am or fm?any idea?
