Author Topic: paano po ba itong C codes sa assembly codes?  (Read 554 times)
Offline joycekram1021
« on: July 16, 2010, 02:11:44 PM »
anu po ba ang syntax nito kapag gagawin siyang assembly?
salamat.
Offline NanotecH
  • Pogi/Ganda Points: 44
Re: paano po ba itong C codes sa assembly codes?
« Reply #1 on: July 16, 2010, 04:20:17 PM »
para saan yan sa PIC uC? ang isang short cut para makuha mo ang equivalent nyan sa assembly ay i-enter mo yan sa C program/compiler (MicroC, etc) at makikita mo dun yung assembly view nyan.
« Reply #2 on: July 16, 2010, 04:36:25 PM »
need pa po ba na complete ung source codes?
or kahit ung part na mismo na gusto ko makita sa assembly?
Offline NanotecH
« Reply #3 on: July 16, 2010, 05:38:35 PM »
yung complete dahil kailangang i-run/compile mo yan bago mo makita ang assembly view
Offline booble
  • Open Source
« Reply #4 on: July 16, 2010, 05:54:15 PM »
Are you referring to x86 assembly language? Mahilig akong gumawa ng inline assembly language routines na ganito sa turbo-c/visual c++ 6 dati. It reduces the binary executable size and reduces execution time.
Selling USBASP AVR/Atmega programmer.
 Ꜿꜿ
  Ɏ
« Reply #5 on: July 19, 2010, 11:47:09 AM »
guys, hindi na po ako makapag'compile ng maayos using assembly simula nung ng PICC Lite ako (C).
last week nagana pa ung codes ko, then now, kahit anung output wala na...
napansin ko lang na hindi na siya MPASM, which is MPASM dapat gamit pag nagbuild using assembly, right?
« Reply #6 on: July 19, 2010, 12:03:20 PM »
i think sa circuit na ung may problema.
thanks.
Offline NanotecH
« Reply #7 on: July 19, 2010, 02:48:59 PM »
buksan mo yung project mo at palitan ng mpasm kung assembly ang ginamit mo, pero kung C naman puedeng PICC.
