Author Topic: Patulong po sa code (assembly)  (Read 1569 times)
  • Pogi/Ganda Points: 53
« on: July 17, 2010, 02:29:30 PM »
#include <p16F84A.inc>
__CONFIG _WDT_OFF & _LP_OSC & _PWRTE_ON
bsf STATUS,5
movlw 0x01
movwf TRISA
movlw 0x00
movwf TRISB
bcf STATUS,5
START
btfss PORTA,0
  movlw 0x0f
movwf PORTB
btfsc PORTA,0
movlw 0xf0
movwf PORTB
end
Nagablink po yung pins ng RB7 to RB5. Pano po iyan gawin na hindi na magblink yung ilaw niyan.
Re: Patulong po sa code (assembly)
« Reply #1 on: July 17, 2010, 04:59:49 PM »
Ok na po pala hehe... here's a revision na ginawa ko:
bsf STATUS,5
movlw 0x01
movwf TRISA
movlw 0x00
movwf TRISB
bcf STATUS,5
START
btfss PORTA,0
  movlw 0x0f
movwf PORTB
btfsc PORTA,0
movlw 0xf0
movwf PORTB
goto START
end
goto START lang pala... hehe...
Mga sir patulong po ulit ako paano po paglagay ng delay sa assembly on MPlab? Yung tut kasi na andito sa akin ibang compiler ang gamit pagtinatry ko yung delay nagaerror na po... Or pahingi na din po nang mga basic source codes na pwedeng pag-aralan pwede sa MPlab... TY :)
« Reply #2 on: July 17, 2010, 05:24:57 PM »
« Reply #3 on: July 17, 2010, 05:52:09 PM »
STACK UNDERFLOW DAW PO SIR simulated sa proteus.
bsf STATUS,5
movlw 0x02
movwf TRISA
movlw 0x00
movwf TRISB
bcf STATUS,5
START
movlw 0xff
movwf PORTB
call delay
movlw 0x00
movwf PORTB
call delay
delay
movlw 0x85
movwf 0x08
decfsz 0x08
RETURN
end
Offline motion55
  • Pogi/Ganda Points: 244
« Reply #4 on: July 17, 2010, 07:02:18 PM »
After the second delay call, a "goto START" must be added. This will prevent the program from falling through to the delay subroutine.
      bsf STATUS,5
      movlw 0x02
      movwf TRISA
      movlw 0x00
      movwf TRISB
      bcf STATUS,5
START
      movlw 0xff
      movwf PORTB
      call delay
      movlw 0x00
      movwf PORTB
      call delay
     goto START
delay
      movlw 0x85
      movwf 0x08
      decfsz   0x08
      RETURN
end
"Set your mind free!"
« Reply #5 on: July 17, 2010, 07:31:06 PM »
Parang walang delay :D DI nagblink :D
« Reply #6 on: July 17, 2010, 08:54:03 PM »
Pano ko po mapapatagal delay nito... halos walang delay yung ginawa ko :D
Offline updated
  • Pogi/Ganda Points: 22
« Reply #7 on: July 17, 2010, 11:12:59 PM »
delay_2sec
movlw .8
movwf 0x20
call msec
decfsz 0x20,f
goto $-2
return
msec movlw .250
nmsec movwf 0x21
msecloop
movlw .248
call micro4
nop
decfsz 0x21,f
goto msecloop
return
onemsec movlw .249
micro4 addlw h'ff'
btfss status,z
goto $-2
return
2sec delay yan, 250msec delay yung msec ehh. try mo po yan sir.
Offline updated
« Reply #8 on: July 17, 2010, 11:17:57 PM »
decfsz   0x08
      RETURN
end
decfsz
 if 1
 if 0
tama po ba sir?
« Reply #9 on: July 18, 2010, 12:00:26 AM »
cblock 0x0C
delay1
delay2
endc
org 0x00
start
call delay_routine
delay_routine
loop
decfsz delay1,f
goto loop
decfsz delay2,f
goto loop
return
end
try mo nga to... ;)
« Reply #10 on: July 18, 2010, 05:44:32 AM »
TY po :)
« Reply #11 on: July 18, 2010, 05:48:55 AM »
cblock 0x0C
delay1
delay2
endc
org 0x00
start
call delay_routine
delay_routine
loop
decfsz delay1,f
goto loop
decfsz delay2,f
goto loop
return
end
try mo nga to... ;)
Working na po! :D Gaano po katagal ito? Pano po pag gusto ko ng specified time
« Reply #12 on: July 18, 2010, 08:58:13 AM »
Mga pogi :D Patulong ulit... di kasi swabe yung pagswitch ng lights :D
org 0x00
  cblock 0x0C
  count1
  count2
  endc
      bsf STATUS,5
      movlw 0x03
      movwf TRISA
      movlw 0x00
      movwf TRISB
      bcf STATUS,5
START
;if RA0 is high then do running lights
  btfsc PORTA,0
  movlw 0x01
  movwf PORTB
  call delay_routine
      rlf PORTB,1
  call delay_routine
  movwf PORTB
      rlf PORTB,1
  call delay_routine
  rlf PORTB,1
  call delay_routine
  rlf PORTB,1
      call delay_routine
  rlf PORTB,1
      call delay_routine
    rlf PORTB,1
      call delay_routine
  rlf PORTB,1
      call delay_routine
  rlf PORTB,1
      call delay_routine
;if RA0 is low then light up all led
  btfss PORTA,0
  call delay_routine
  movlw 0xff
  movwf PORTB
goto START
delay_routine
loop
decfsz count1,f
goto loop
decfsz count2,f
goto loop
return
end
Sa unang switch nung RA0 nagablink pa din yung unang led(RB0).
« Reply #13 on: July 18, 2010, 11:04:29 AM »
count2 and count1 are initialized to zero however when it decremented on the delay_routine function, it becomes 255 hence making the condition always false causing it to decrement further until such time it reaches 0.
The inner loop will take 256 * 3 inst cyc plus 3 inst cyc. and it will be executed for another 256. so parang
((256*3)+3)*256  = 197376 instruction cycle.
kung 4Mhz ang oscillator mo, e di may 4Mhz/4 = 1Mhz ka na instruction frequency or 1us na instruction period.
it follows that...
197367 x 1us = 0.197367s or ~197ms ang magiging delay mo.
you could play with the values of count1 and count2 variables. You could initialize it inside the delay_routine, just before the loop "label". I suggest you calculate it so that you could follow. Try it first on Proteus and verify it with the oscilloscope tool - check the delay you wanted.
I also suggest that you'd consider using the TIMER0 module since this is available with F84a.
« Reply #14 on: July 18, 2010, 11:44:55 AM »
delay_routine
loop
decfsz count1,f
goto loop
decfsz count2,f
goto loop
return
Pwede din po ba ito sa ibang pic?
Paano po naging ganyan yung formula? :D
« Reply #15 on: July 18, 2010, 11:46:48 AM »
oo naman.. we call it software delay.
« Reply #16 on: July 18, 2010, 12:07:01 PM »
org 0x00
cblock 0x0C
count1
count2
endc
bsf STATUS,5
movlw 0x00
movwf TRISB
bcf STATUS,5
main
movlw 0x80
movwf PORTB
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
goto main
delay_routine
 loop
    decfsz count1,0xff
   goto loop
 decfsz count2,0xff
 goto loop
return
end
yung second turn ng running lights dalawa na yung umiilaw :( Panu yun gawin isa lang?
« Reply #17 on: July 18, 2010, 12:58:11 PM »
Try this... note di ko to na try
cblock 0x0C
count1
count2
endc
org 0x00
bsf STATUS,5
movlw 0x00
movwf TRISB
bcf STATUS,5
movlw 0x80
movwf PORTB
main
rrf PORTB,1
call delay_routine
goto main
delay_routine
loop
decfsz count1,0xff
goto loop
decfsz count2,0xff
goto loop
return
end
« Reply #18 on: July 18, 2010, 01:15:56 PM »
Ty po kuya :)
« Reply #19 on: July 18, 2010, 01:31:54 PM »
Paano po ito? ang haba pano toh mas mapapaikli may way pa ata para mapaikli toh...
org 0x00
cblock 0x0C
  count1
  count2
 endc
      bsf STATUS,5
      movlw 0xff
      movwf TRISA
      movlw 0x00
      movwf TRISB
      bcf STATUS,5
main
movlw 0x00
movwf PORTB
btfss PORTA,0
goto sw1
btfss PORTA,1
goto sw2
btfss PORTA,2
  goto sw3
goto main
sw1
;if RA0 is high then do running lights rlf
  btfss PORTA,0
  movlw 0x01
      movwf PORTB
  call delay_routine
      rlf PORTB,1
  call delay_routine
  movwf PORTB
      rlf PORTB,1
  call delay_routine
  rlf PORTB,1
  call delay_routine
  rlf PORTB,1
      call delay_routine
  rlf PORTB,1
      call delay_routine
    rlf PORTB,1
      call delay_routine
  rlf PORTB,1
      call delay_routine
  rlf PORTB,1
      call delay_routine
    btfsc PORTA,0
  goto main
goto sw1
; ON OFF
sw2
btfss PORTA,1
movlw 0xff
movwf PORTB
btfsc PORTA,1
goto main
goto sw2
; running lights rrf
sw3
movlw 0x80
movwf PORTB
btfss PORTA,2
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
rrf PORTB,1
call delay_routine
btfsc PORTA,2
goto main
goto sw3
delay_routine
  loop
      decfsz count1,0xff
    goto loop
  decfsz count2,0xff
  goto loop
return
end
