First agenda:
IDE problem, a month ago when I turned my on my computer it won't boot... there was a warning in bright red text about IDE problem...and the computer emitted sharp sounds (w/c happens whenever the RAM gets loose...)... i didn't mind the warning at first thinking that it was only the RAM...but then the pc won't load so there... i read the warning it said that i had to switch my seondary slave to primary (to w/c i did) but the poor device still didn't boot... so i had to uninstall my cd-rom drive... w/c is very inconvinient...
now i need to fix this 'IDE' prob because i need to burn some files... but i'm afraid that another warning will show... what should i do? (i don't want to spend because i'm only a student and i'm on 'fix your own electronic device mode')
Second Agenda:
My keyboard got accidentally spilled by iodine povidone commonly known as betadine... it still worked but it's not functioning well... i fixed it a bit, but unfortunately it's still malfunctioning... i believe that it can still be fixed but i need some advice on how to make it work again... (i already cleaned the inside of the keyboard including the clear plastic inside). the keyboard is still in fine condition but yeah it malfunctions because of the liquid that had been accidentally spilled on to it.
thanks in advance guys
