@malditah : sino yung organizer sorry wala ako idea na may convention
@ amadjo : 1 watt is 85p 3 is 150 and 5 watts is 300
Stocks
eto ginawa ko driver.Parts are from e-gizmo. I did use some replacement. I'll try to post pictures when I'm done testing it.Output are connected to a 5Watt LED. It delivers 240mA at around 10-14V. Not enough for 5W but will work on 2pcs 1Watt LED.
More Item20 Watts Hi-Power White L.E.D. 1400Lumens 13.5~15V - 1,700Php30 Watts Hi-Power White L.E.D. 2400Lumens 15~18V - 2,600Php100 Watts Hi-Power White L.E.D. 7000Lumens 30~35V - 7500Php8MM's1W StrawHat 8mm 140° High Power White LED 220Kmcd - 90Php
