Author Topic: WIRELESS ROUTER HELP!  (Read 2701 times)
Re: WIRELESS ROUTER HELP!
« Reply #40 on: January 29, 2011, 07:17:31 PM »
^Di ko pa nasubukan yan. Check ko minsan.
Sis potato alam ko kapag dhcp enable automatic magbibigay siya ng ip add na kilala nung router para di magconflict sa IP add, yung router mismo nag aasign. Di ko pa nasubukan kung ikaw maglagay ng IP add sa ibang computer kung eh recognized ng router.
Alam kung ibang settings dyan ay block mo yung internet access pero makakonek sa network mo lang.
Offline /
  • Pogi/Ganda Points: 317
« Reply #41 on: January 29, 2011, 09:40:44 PM »
ok na pala! congrats!.. WEP' pano po yan kahit sino pwede na makaconnect dyn kahit kapitbahay..
may makakapag paliwanag kaya nito kung anu ang hiwaga sa ganitong sitwasyon..
« Reply #42 on: January 29, 2011, 09:42:14 PM »
Sige patanong na rin lang ako.
Offline de PatAtas
  • Pogi/Ganda Points: 330
  • ' The unbreakable
« Reply #43 on: January 30, 2011, 10:35:38 AM »
' na try ko na yan dito sis..15 pc tapos dalawang ng laptop na na pwede sa wireless router.....nilagyan ko ng Ip bawat isa Pati po DNS SERVER....ok lang nman po... connected po network..at internet..
« Reply #44 on: January 30, 2011, 01:20:03 PM »
Ah parang yatang ganito kapag di dhcp auto. Di mo mablock specifically kung anong pc ang iblock kasi hahanapin mo pa siya di katulad ng manually configure nakaroute kaagad dun. Katapos kapag block mo naman. Reset lang sya uli ibang ip uli ibibigay ng router.
Offline lapigut!
  • Pogi/Ganda Points: 49
« Reply #45 on: April 16, 2011, 02:27:43 AM »
pinalitan ko nga lang ng WEP yung encrpytion...
i think hindi advisable ang WEP as security kasi may hacking software na para don...why not use a WPA2 security instead???and para mtest mo kung gmgana ang router mo, gumamit ka ng ping command sa command prompt going to the router..
kutsarain ang mainit na sabaw
Offline Davidoram
« Reply #46 on: March 22, 2012, 07:33:44 PM »
Initially confirm you want a wireless router as from what you have described you can do it with a reversed connected cat5 lead between the two machines.You require an internet router from Verizon or whoever provides you, and Wireless-G Broadband Router. The modem must be accomplished of sending signals, which your lap top's wifi connectivity will identify and loop through.
Offline dipblu
« Reply #47 on: March 23, 2012, 10:22:16 AM »
Sir, mas mas ok sana kung wpa2 as a security kaya lang may issue ito sa vista. kaya talagang kailangang gamitin mo yung WEP as an alternate. mas mahina nga lang ang security mo. na try mo na bang mag mac filtering?
