Author Topic: help with my Globe Modem/Router to DLink Switch  (Read 1083 times)
Offline luibog
« on: July 25, 2010, 11:34:45 PM »
Patulong naman kc ung Modem/Router na kinabit sakin ng globe hindi ko ma configure papunta sa switch na dlink, anong klasing cabling ba ggwin pag modem/router to switch?crossover or straight?
switch to PC?crossover or straight?
tapos pala wala kc WAN port ung Switch ko 16PORTS sya 1-16 wala na iba nakalagay
tnx
Offline jamz
Re: help with my Globe Modem/Router to DLink Switch
« Reply #1 on: July 28, 2010, 08:30:11 AM »
Anong brand ba ng router/modem gamit mo? Usually utp cable na straight lang ang ginagamit diyan from modem/router to your switch hub, then automatic na dhcp na yan. just make sure na yung gateway IP ng pc mo ay ung local ip address ng modem mo.
  • Pogi/Ganda Points: 635
« Reply #2 on: July 28, 2010, 10:01:28 AM »
ano 'yung Modem? baka hindi naka-configure ng maayos 'yung DHCP. puro straight lang 'yan. ang crossover typical na ginagamit sa same level equipment (router to router, PC to PC, etc.), though merong ilang equipment na crossover ang gamit like 'yung ZTE MF600.
BTW, marami na ring equipment ngayon auto MDI/MDI-X kaya minsan 'di na masyadong concern 'yung straight/crossover.
Offline luibog
« Reply #3 on: July 28, 2010, 10:35:18 PM »
prolink 6300g modem/router, tapos ung GUI sa WEB PAGE para ma access eh iba d tulad sa linksys ang hirap i configure,d ko alam kung pano ko lilimit bandwidth ng bawat pc,gusto ko sana sa modem nlng ung limit para d na ko mag iinstal sa bawat pc ng bandwidth limiter
Offline akhen
  • Pogi/Ganda Points: 47
« Reply #4 on: July 28, 2010, 10:47:29 PM »
sir ano nangyayari pag kinonek mo yung switch sa router? sa switch kc kukuha ka lang ng isang port nya at dun mo ikakabit yung cable galing sa modem mo... tapos yung mga pc kabit sa switch... straight cable lang gamitin mo sir...
Offline shadowstriker07
  • Pogi/Ganda Points: 10
  • DELL Business Printer Hardware Warranty Support
« Reply #5 on: July 28, 2010, 11:00:34 PM »
uhhh you have Prolink modem/router...... na papuntang D-Link?.... tama ba?
hindi pede yan.....
it's Prolink Modem/Router => HUB..... (you dont need the D-Link router anymore)
d pede dalawa router on the same network  or else walang internet connection kung meron man hirap maka connect ang mga PC sa network through internet...
kung gusto mo Prolink Modem/Router => D-Link
connect Prolink Modem/Router port => 2nd port of D-Link =>3rd port of of Dlink =>HUB
effect:   mahina ang response ng internet through the network...
            you had to reset each LAN connection of PC para maka connect ng maayos
            ung D-Link actually magiging HUB lng xa....(recommended only kung wala kang HUB pra makaconnect p ung ibang PC)
straight Thru cable nga pala ang set-up
Blow Job!!!.. Is the Only WORD that cannot be written on a resume` despite of years of Experience and References
Offline jamz
« Reply #6 on: July 28, 2010, 11:14:49 PM »
kailangan makuha mo muna yung admin password ng globe.. usually naka lock yan..  google mo lang muna.. usually http://192.168.1.1/globe   yan.   then try to go to lan then check mo settings. ung dlink switchhub ay dapat naka default config muna. Kung gumagamit ka ng enterprise class na dlink switchhub (pang corporate or isp) yan ung mga merong bandwidth limiter, ung ordinary dlink switch hub ay wala niyan. automatic na dapat na pag ikinabit mo sa router yan gagana kaagad.. try to reset ung switch hub muna.  At kung makakapasok ka using the admin password ng globe, try to save settings muna bago mo galawin yang modem/router.
Prolink din gamit ko at globe din pero di ito wireless class - prolink hurricane 5200 lang ang akin.  Ung sa iyo ay  merong wireless yata, na dapat ay naka-disable para di magamit ng kapitbahay?
« Reply #7 on: July 29, 2010, 07:32:24 AM »
bale nakaka-connect naman mga PC sir? kailangan niyo lang i-limit bandwidth? karamihan ng mga modem na 'to very basic 'yung makikitang configurations sa GUI. though pwedeng makakuha ng idea sa ibang forums, kailangan nga lang buksan 'yung modem para ma-access 'yung serial port. majority naman nitong mga modem naka-Linux server.
kung 'di kakalikutin 'yung loob, kailangan ng switch na may control, or kailangan ng second router na mas maraming control, sa WAN ikakabit.
