Author Topic: Electroplating  (Read 3510 times)
Offline fantom_mayonaise
  • Pogi/Ganda Points: 30
Re: Electroplating
« Reply #20 on: June 16, 2008, 09:44:10 AM »
diba parang battery yong operation ng electroplating dapat + material yng isa at negative mterial naman yong isa tapoos may conductive liquid to at certain amount of cureent to transfer the negative material to the positive material...ganon ba yon?? tama ba yon?? taka ako sa boos ko kasi sabi nya he electroplate a plant leaf with all the details of the leaf...i not sure how true kasi hindi ko panam nakita ang sampol niya....
posible ito... bale ang ginagawa, nilalagyan muna ng conductive coating yung article bago simulan yung plating. Dun sa coating kakapit yung plating. Nabasa ko dati parang ginagawa nilang business din datin na i-plate yung first shoes ng babies sa america, remembrance ba.
Re: Electroplating
Offline mikel
Re: Electroplating
« Reply #21 on: June 16, 2008, 01:12:45 PM »
Tama ang ilan sa inyo, I used to have electroplating business in 1997 and I stop operation in 2000. The reasons, masyado kasi matrabaho at risky sa health. Kahit hindi ako ang nagwo-work dahil me tao ako pero yung fumes ay ayaw ko. Imagine you are dealing with the most poisonous chemicals on earth. Hindi talaga kakapit ang anomang metal oxide kapag marumi. You have to smooth out surfaces, sanding, grinding and buffing. Pagkatapos pakukuluan mo pa sa cleaning solutions.
 Plating with copper uses low current while in gold is higher.
Re: Electroplating
Offline ♪ ♫ ♫ ♪ ♪ ♪ ♫ ♫ ♫
Re: Electroplating
« Reply #22 on: June 18, 2008, 08:34:08 PM »
Okey ang experience nyo sir, matanong ko lang po kung paano ba yong Tin plating ng PCB?  ???
Re: Electroplating
Offline rhodect
Re: Electroplating
« Reply #23 on: February 17, 2012, 01:43:11 AM »
hello mga amigo... ako po si rhodect.. sino po kaya sa kanila makakatulong sa akin regarding plastic electroplating. :)
Re: Electroplating
Offline rhodect
Re: Electroplating
« Reply #24 on: February 17, 2012, 01:47:32 AM »
Re: Electroplating
