Author Topic: Line Follower Mobot Using PIC16f84a  (Read 880 times)
Offline mini_mouse ^_^
  • he's keeping it up, I should take pride :)
« on: August 06, 2010, 10:23:35 AM »
...hello..
any one here could give me some inputs about the concept of making Line follower mobot using pic16F84a.... :)
...I'm thankful each and every day, coz I found you...
Re: Line Follower Mobot Using PIC16f84a
« Reply #1 on: August 06, 2010, 11:33:05 AM »
it's fairly simple sis, bale may line sensor ka at lease 3. and dalawang dc motors.
kapag triggered yung center sensor then sabay aandar yung motor. if triggered yung left sensor titigil yung right motor... vise versa.
« Reply #2 on: August 07, 2010, 09:41:13 AM »
bali ung DC motor ko ang placement nya, is for the right tires and left tires?
  • Pogi/Ganda Points: 203
« Reply #3 on: August 07, 2010, 09:48:04 AM »
kindly search the forum, may dalawang example na posted na dito using PIC16F84A, differential drive and the front steering type, pinned ito sa mechatronics and robotics section kaya madali mo lang makikita
« Reply #4 on: August 07, 2010, 10:14:50 AM »
salamat po.
« Reply #5 on: August 21, 2010, 06:07:25 PM »
..hello.. just to confirm... if yung pins ng pic16f84a na Ra0-Ra3 if iconfigure ko po as input.... voltage applied from 0.8V - higher, logic  1 po ba xa...? then logic 0 if below 0.8 V?
« Reply #6 on: August 23, 2010, 02:49:12 PM »
^ undefined zone po yun.
yung blue zones means yung logic level nya.
it might work or it might not work as logic high kung nasa undefined ka.
