Author Topic: ePIC-KIT2 PIC USB Programmer and Debugger  (Read 1042 times)
Offline mini_mouse ^_^
  • he's keeping it up, I should take pride :)
« on: August 18, 2010, 04:43:37 PM »
Paano po ba gamitin yan.. hehehe.. ng-order po kasi kami ng loader for Pic 16f84a sa e-gizmo...
parallel interface at usb interface po... ok po yung parallel interface kasi nakita na namin paano xa gagamitin..
eto pong usb interface na( ePIC-KIT2 PIC USB Programmer and Debugger) paano po ba i-loload yung program dito? pahelp naman po..
...I'm thankful each and every day, coz I found you...
Re: ePIC-KIT2 PIC USB Programmer and Debugger
« Reply #1 on: August 18, 2010, 04:56:00 PM »
bilhin mo muna. it's a very good programmer btw.
« Reply #2 on: August 18, 2010, 05:01:48 PM »
Normally you will have to use ICSP to program your pic but you can also create a sort of breakoutboard with zif socket.  The pc software needed, you can download from microchip website either yung pickit 2 application s/w or the latest mplab ide.
« Reply #3 on: August 18, 2010, 05:11:12 PM »
nabili na po namin.. hndi po namin alam paano xa gamitin..
Offline marcelino
  • Pogi/Ganda Points: 258
« Reply #4 on: August 18, 2010, 06:01:22 PM »
hi stepipai,
ePICKit2 is an exact (almost) clone of the genuine PICKIT2. I said almost because it is basically based on the genuine however e-gizmo replaced some of its components with equivalent part. example would be the opamp which they replaced it with one from analog devices (yung nagamit ko).
I suggest you read the details of how to use it by first installing the PICKit2 software which you could directly download from microchip.com
here's the direct link for the pickit2 page: http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023805
Read the "PICkit 2 Microcontroller Programmer User's Guide". You will see it from the help menu of the pickit2 software.
keep digging :)
« Reply #5 on: August 20, 2010, 09:52:10 AM »
...saan po ma.dl ung Pickit 2 microcontroller programmer user's guide sir marci? :) jan din po ba sa link na bibigay nyu?
 may installer na po kasi na kasama yung epickit2 galing sa e-gizmo sir... hindi po kasi namin makita yung tutorial nya...
Offline marcelino
« Reply #6 on: August 20, 2010, 10:24:49 AM »
yes.. nandyan lahat. basahin mo yung page.
di ko alam kung anong kasama sa installer ng e-gizmo. di ko naman kasi yan nagamit. but im quite sure na pareho lang naman nung pickit 2 software yan.
basahin mo yung page, may mga application notes pa dun na maaaring makatulong sayo.
here's the direct link for installer: http://ww1.microchip.com/downloads/en/DeviceDoc/PICkit%202%20v2.61.00%20Setup%20A.zip
eto naman ang user's guide: WWW.SecureSoftwareList/secsoftwaredownload.aspx?device=en023805&lang=en&ReturnURL=http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023805#]http://www.microchip.com/Microchip.[url=http://WWW.SecureSoftwareList/secsoftwaredownload.aspx?device=en023805&lang=en&ReturnURL=http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023805#]WWW.SecureSoftwareList/secsoftwaredownload.aspx?device=en023805&lang=en&ReturnURL=http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023805#[/url]
« Reply #7 on: August 20, 2010, 10:44:03 AM »
...bad request po yung link sir..
Offline marcelino
« Reply #8 on: August 20, 2010, 11:03:42 AM »
punta ka nalang dun sa main page... para na din makita mo yung ibang info's.
Offline black_circuit1
« Reply #9 on: October 26, 2010, 04:43:55 PM »
di pa kasi ako nakakagamit ng ePIC-KIT2 by e-gizmo eh... is it the same with universal PIC programmer ng e-gizmo in terms of programming different PIC like 16f84a????????
Offline Tarkov24
« Reply #10 on: October 26, 2010, 10:38:29 PM »
same lang software na gamit ng pickit2 at ePickit2 ng e-gizmo para maDL yung hex to MCU. may ICSP kasi ako na gamit sa pag gumagamit ako ng nito, pero kung wala ka ICSP pwede naman breadboard gamitin, sundin nalang po yung mga pin connections sa MCU... kung hiindi mo pa rin mahanap/ma-access yung info na kailangan mo balik ka lang dito post ko yung link para maDL mo tutorials..
BANANA YELLOW IS A HAPPY COLOR!!!
