Sending Command: ATDelay: 50msecReceived Reply:ATOK===========================Sending Command: AT+CMGF=1Delay: 50msecReceived Reply:AT+CMGF=1OK===========================Sending Command: AT+CMEE=2Delay: 50msecReceived Reply:AT+CMEE=2OK===========================Sending Command: AT+CSCS="UCS2"Delay: 50msecReceived Reply:AT+CSCS="UCS2"OK===========================Sending Command: AT*PSSTK="SETUP MENU",1,1Delay: 200msecReceived Reply:AT*PSSTK="SETUP MENU",1,1OK*PSSTK: "END SESSION"===========================Sending Command: AT*PSSTK="GET ITEM LIST",5Delay: 300msecReceived Reply:AT*PSSTK="GET ITEM LIST",5*PSSTK: "GET ITEM LIST",1,1,4,"myGlobe",0,0,0*PSSTK: "GET ITEM LIST",2,2,4,"Prepaid Svcs",0,0,0*PSSTK: "GET ITEM LIST",3,3,4,"GCASH",0,0,0*PSSTK: "GET ITEM LIST",4,4,4,"Specials",0,0,0*PSSTK: "GET ITEM LIST",5,5,4,"myFavorites",0,0,0OK===========================Sending Command: AT*PSSTK="MENU SELECTION",2Delay: 300msecReceived Reply:AT*PSSTK="MENU SELECTION",2OK*PSSTK: "SELECT ITEM",1,4,"Prepaid Svcs",0,0,1,0,0,7===========================Sending Command: AT*PSSTK="GET ITEM LIST",7Delay: 300msecReceived Reply:AT*PSSTK="GET ITEM LIST",7*PSSTK: "GET ITEM LIST",1,1,4,"Globe Promos",0,0,0*PSSTK: "GET ITEM LIST",2,2,4,"CallTextSvcs",0,0,0*PSSTK: "GET ITEM LIST",3,3,4,"Check Balance",0,0,0*PSSTK: "GET ITEM LIST",4,4,4,"Reload",0,0,0*PSSTK: "GET ITEM LIST",5,5,4,"Int'l Roaming",0,0,0*PSSTK: "GET ITEM LIST",6,6,4,"GPRS Settings",0,0,0*PSSTK: "GET ITEM LIST",7,7,4,"Call Cust Svc",0,0,0OK===========================Sending Command: AT*PSSTK="SELECT ITEM",1,3,0,0Delay: 3000msecReceived Reply:AT*PSSTK="SELECT ITEM",1,3,0,0OK*PSSTK: "NOTIFICATION",1,19,0,255,"",0,0=================================================================END===========
// AT Command Demo for Accessing Sim Toolkit via SIM900D GSM ModemAT|TRUE|50|NoneAT+CMGF=1|TRUE|50|NoneAT+CMEE=2|TRUE|50|NoneAT+CSCS="UCS2"|TRUE|50|NoneAT+CMGD=40|TRUE|500|Make sure index 40 is erasedAT*PSSTK="SETUP MENU",1,1|TRUE|200|1 time call onlyAT*PSSTK="GET ITEM LIST",5|TRUE|200|NoneAT*PSSTK="MENU SELECTION",2|TRUE|200|Choose Prepaid SvcsAT*PSSTK="GET ITEM LIST",7|TRUE|200|NoneAT*PSSTK="SELECT ITEM",1,3,0,0|TRUE|5000|Choose Balance InquiryAT*PSSTK="NOTIFICATION",1,0|TRUE|500|NoneAT+CSCS="GSM"|TRUE|10000|NoneAT+CMGL="REC UNREAD"|TRUE|500|None
Sending Command: ATDelay: 50msecReceived Reply:ATOK===========================Sending Command: AT+CMGF=1Delay: 50msecReceived Reply:AT+CMGF=1OK===========================Sending Command: AT+CMEE=2Delay: 50msecReceived Reply:AT+CMEE=2OK===========================Sending Command: AT+CSCS="UCS2"Delay: 50msecReceived Reply:AT+CSCS="UCS2"OK===========================Sending Command: AT+CMGD=40Delay: 500msecReceived Reply:AT+CMGD=40OK===========================Sending Command: AT*PSSTK="SETUP MENU",1,1Delay: 200msecReceived Reply:AT*PSSTK="SETUP MENU",1,1OK*PSSTK: "END SESSION"===========================Sending Command: AT*PSSTK="GET ITEM LIST",5Delay: 200msecReceived Reply:AT*PSSTK="GET ITEM LIST",5*PSSTK: "GET ITEM LIST",1,1,4,"myGlobe",0,0,0*PSSTK: "GET ITEM LIST",2,2,4,"Prepaid Svcs",0,0,0*PSSTK: "GET ITEM LIST",3,3,4,"GCASH",0,0,0*PSSTK: "GET ITEM LIST",4,4,4,"Specials",0,0,0*PSSTK: "GET ITEM LIST",5,5,4,"myFavorites",0,0,0OK===========================Sending Command: AT*PSSTK="MENU SELECTION",2Delay: 200msecReceived Reply:AT*PSSTK="MENU SELECTION",2OK*PSSTK: "SELECT ITEM",1,4,"Prepaid Svcs",0,0,1,0,0,7===========================Sending Command: AT*PSSTK="GET ITEM LIST",7Delay: 200msecReceived Reply:AT*PSSTK="GET ITEM LIST",7*PSSTK: "GET ITEM LIST",1,1,4,"Globe Promos",0,0,0*PSSTK: "GET ITEM LIST",2,2,4,"CallTextSvcs",0,0,0*PSSTK: "GET ITEM LIST",3,3,4,"Check Balance",0,0,0*PSSTK: "GET ITEM LIST",4,4,4,"Reload",0,0,0*PSSTK: "GET ITEM LIST",5,5,4,"Int'l Roaming",0,0,0*PSSTK: "GET ITEM LIST",6,6,4,"GPRS Settings",0,0,0*PSSTK: "GET ITEM LIST",7,7,4,"Call Cust Svc",0,0,0OK===========================Sending Command: AT*PSSTK="SELECT ITEM",1,3,0,0Delay: 5000msecReceived Reply:AT*PSSTK="SELECT ITEM",1,3,0,0OK*PSSTK: "NOTIFICATION",1,19,0,255,"",0,0===========================Sending Command: AT*PSSTK="NOTIFICATION",1,0Delay: 500msecReceived Reply:AT*PSSTK="NOTIFICATION",1,0OK===========================Sending Command: AT+CSCS="GSM"Delay: 10000msecReceived Reply:AT+CSCS="GSM"OK*PSSTK: "END SESSION"===========================Sending Command: AT+CMGL="REC UNREAD"Delay: 500msecReceived Reply:AT+CMGL="REC UNREAD"+CMGL: 40,"REC UNREAD","GLOBE","","10/08/19,23:53:22+32"Your Account Balance as of 08/19/2010 23:53 is 0.00 You also have 0 remaining FREE texts.=================================================================END===========
ATD2629;|TRUE|10000|Dial 2629AT+VTD=100|TRUE|100|Setup 100msec DTMF DurationAT+VTS="0"|TRUE|2000|Send 0 DTMF to enter Globe's Customer Care AT+CLCC|TRUE|100|Request Status
Sending Command: ATD2629;Delay: 10000msecReceived Reply:ATD2629;OK===========================Sending Command: AT+VTD=100Delay: 100msecReceived Reply:AT+VTD=100OK===========================Sending Command: AT+VTS="0"Delay: 2000msecReceived Reply:AT+VTS="0"OK===========================Sending Command: AT+CLCCDelay: 100msecReceived Reply:AT+CLCC+CLCC: 1,0,0,0,0,"2629",129,""OK=================================================================END===========
^very nice cellfone!
sir whats the difference between SIM450D and SIM900D?
wala namang product na SIM450D ... yung sa e-gizmo gamit nila ay SIM340D/Z kahit sa website ng simcom walang SIM450D
Making a call using E-Gizmo's GSM Modem My Setup http://img821.imageshack.us/gal.php?g=setupqt.jpgPC Microphone + CD-R king salvaged earphones Connections (out of focus ang pic! )Using AT Command Script Processor, here is the script to make callsCode: [Select]ATD2629;|TRUE|10000|Dial 2629AT+VTD=100|TRUE|100|Setup 100msec DTMF DurationAT+VTS="0"|TRUE|2000|Send 0 DTMF to enter Globe's Customer Care AT+CLCC|TRUE|100|Request StatusHere is the resultCode: [Select]Sending Command: ATD2629;Delay: 10000msecReceived Reply:ATD2629;OK===========================Sending Command: AT+VTD=100Delay: 100msecReceived Reply:AT+VTD=100OK===========================Sending Command: AT+VTS="0"Delay: 2000msecReceived Reply:AT+VTS="0"OK===========================Sending Command: AT+CLCCDelay: 100msecReceived Reply:AT+CLCC+CLCC: 1,0,0,0,0,"2629",129,""OK=================================================================END===========nakipag chika chika lang ako sa Customer care, kunwari may problem sa sim ng globe pero tinetesting ko lang yung clarity ng voice at kung maririnig nya ako
