Author Topic: LCD running message display using pic16f84a  (Read 2264 times)
Offline reve4321
« on: August 26, 2010, 04:20:43 PM »
pahelp naman po.. paano po ba makadisplay ng running message sa LCD gamit ang pic16f84a??? assembly language po ang gamit naming programming language...  :D
Re: LCD running message display using pic16f84a
« Reply #1 on: August 26, 2010, 04:47:06 PM »
Medyo madugo yan  ..... sigurado ako around 1000 lines of codes ang aabutin niyan.
Lets wait for the masters to reply but kung medyo masipag kayo mag-reverse engineer tutal asm naman pinag-aaralan ninyo, you can actually trace the asm codes generated by a high language like c or basic.
Offline NanotecH
  • Pogi/Ganda Points: 44
« Reply #2 on: August 27, 2010, 11:14:29 AM »
depende yan kung anong klaseng LCD ang gagamitin nyo, gaano kahabang message ang idi-display at available memory (internal & external).
kailangan i-layout mo muna ang circuit at i-check ang datasheet ng LCD para malaman nyo ang available commands.
sa pag-program may mga makakatulong sayo pero hangga't wala ang circuit medyo mahihirapan ka dahil hindi mo alam kung aling output ang kailangan mong i-program.
« Reply #3 on: August 27, 2010, 11:53:21 AM »
IIRC, yung nabasa kong e-book ng MikroC last 2008 eh may library for 2x16 LCD..  HD44780 LCD Driver..
Offline reve4321
« Reply #4 on: August 27, 2010, 10:38:41 PM »
sc162a3 rev 2.0 ang gamit naming LCD.. mga at most 16 bit character ang idi-display namin... naghanap kami ng datasheet nito sa net pero di namin maintindihan.. chinese characters kc nakalgay.. huhuh..
Offline NanotecH
« Reply #5 on: August 28, 2010, 02:56:14 AM »
ano ba may gawa nyan digitron?
kung digitron check mo dito:
Digitron character LCD
Digitron LCD SC162A
Digitron Usage manual, may Instruction table, CG ROM display, Interfacing info na dito.
SC162A rev2.1 in pdf file, kumpleto na ito.
Offline reve4321
« Reply #6 on: August 28, 2010, 04:01:38 PM »
wow! thankz guys.. ang laking tulong ang ibinigay niyo.. ehehhe..
