Author Topic: Globe Tattoo USB Modem in VB6, finally..  (Read 23209 times)
Offline john _already
Re: Globe Tattoo USB Modem in VB6, finally..
« Reply #520 on: February 23, 2012, 09:58:02 AM »
tnx sir i realy need the code ..sinu po may alam kung panu e retrieve ung inbox through html...read lang kahit wala nang send..d kasi aq maruning masyado sa programing
Offline ece_valz
« Reply #521 on: February 24, 2012, 01:32:41 AM »
sir, pwede po ba machange ung commport number during runtime? i have used a message box as input in mscomm1.commport.
With MSComm1
        If .PortOpen Then .PortOpen = False
           .CommPort = txtcomport
           .Settings = "9600,N,8,1"
           .DTREnable = True
           .RTSEnable = True
           .RThreshold = 1
           .SThreshold = 0
           .PortOpen = True
  End With
but i always get an invalid port number error. where infact the number i inputted in the textbox is the com number found in device manager-> modems-> huawei->properties-> modem->port, in my case com9. when i manually wirte 9 in mscomm1.commport=9 and change the comport in properties window of vb6, it is works.
i'm thinking maybe the input number of comport in the code should coincide with the comport in the properties window. if this is the case then i won't be able to change it during runtime... or iam missing something crucial here... please guide po.... tnx for the future replies...
  • Pogi/Ganda Points: 635
« Reply #522 on: February 24, 2012, 02:57:18 AM »
^ perhaps you really are missing something crucial. the textbox input is most probably a string, the CommPort property most probably requires an integer. ;)
Offline ece_valz
« Reply #523 on: February 24, 2012, 10:12:16 AM »
tnx 4 the reply... ung txtcomport pala ay nasa ibang form!! ahhahaha
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #524 on: February 26, 2012, 07:03:08 AM »
^^^ Yan din ang plano ko sa ibang project ko na gawin nalang sa ibang form ang mga port settings.
You can change the comport at run time. But rule of thumb na pag hindi muna gagamitin ang port, i-close dapat tsaka na gagamit ng iba.
Offline dummy_c
« Reply #525 on: February 26, 2012, 07:38:46 AM »
sir sino po may code para sa receiving lang ng tex..... kahit d maka send. kasi yong kang sir redhorse e d na ma dl..yong link na binigay wala nag buhay
Sino si redhorse? ;D
Anyway ito last na ginawa ko sir paki edit nalang,
http://www.filehosting.org/file/details/316123/GlobeTattooVB6.zip
Be careful sa donate button, mag share-a-load yan sa number ko. ;D ;D
Pwedi din yan ilagay sa form_load, assuming naka connect na sa modem ang program. Then auto eraze mo lang ang confirmation sa share-a-load, detect mo ang 4438 na sender's number. Then bigay mo sa mga friends mo. ;D
Offline dummy_c
« Reply #526 on: February 26, 2012, 07:43:24 AM »
If di ka pa masyado marunong sir, huwag muna yan..hehe.
Joke!
Pwedi ka maggawa ng web browser sa vb6, you start from there. But be careful wala siyang security features.
  • Pogi/Ganda Points: 53
« Reply #527 on: February 26, 2012, 10:25:37 AM »
kung gusto mo.. bago magdelete isesend sa email you yung logs via email.. Pano mu gagawin toh?
kunin mu smtp server and port number ng mail(yahoo,gmail, etc.)  .. ung outgoing ha..
« Reply #528 on: February 26, 2012, 10:58:25 AM »
tnx Nga pala dto sir...its a big help...try ko nalang connect to sa database..pero panu? hehe
Offline Kid Kulafu
« Reply #529 on: February 26, 2012, 02:55:00 PM »
I've tried using C# and successfully send/receive using Tattoo and SmartBro usb modem.
Offline dummy_c
« Reply #530 on: February 26, 2012, 03:10:34 PM »
^ And let me guess, it's not sharable? ;D ;D ;D
« Reply #531 on: February 26, 2012, 03:34:12 PM »
;D ;D ;D
Offline Mayor Johnaray
  • Pogi/Ganda Points: 238
« Reply #532 on: February 26, 2012, 03:47:08 PM »
Care to share ;D ;D ;D
« Reply #533 on: February 26, 2012, 03:52:22 PM »
pscode.com
search mu yung mga adodc/adodb.
Offline dummy_c
« Reply #534 on: February 26, 2012, 03:54:45 PM »
Tama nga ako, nawala na siya... ;D ;D ;D ;D
Sana matapos ko na ang para sa vb9.
Maka serially send/receive na ako ng strings, kaso hindi ko ma receive ang response ng tattoo.  >:(
« Reply #535 on: February 26, 2012, 04:09:05 PM »
buti ka pa.. ako di na nakapagpoprogram,,
Offline glenntrinidad
« Reply #536 on: March 14, 2012, 10:53:45 AM »
gud job to this sir, ask ko lang qng wala ka bang ibang ocx n ginamit aside s MSCOMM1? or if any, pde b aqng makahingi ng full copy ng system mo s vb6? interested kc aq s system mo tlg... and i found it very useful kht saan... thnx in advance and more systems to accomplish...
by the way, here is my email: glennpaulo_trinidad@yahoo.com
Happy programming...  8)
Offline mini_mouse ^_^
  • Pogi/Ganda Points: 7
  • he's keeping it up, I should take pride :)
« Reply #537 on: April 20, 2012, 05:15:03 PM »
@TS:
e sa mga web applications po, nakapagTry na po ba kayo na mgsend ng Text Msg...?
...I'm thankful each and every day, coz I found you...
Offline chard5230
« Reply #538 on: June 28, 2012, 12:33:48 AM »
aww.. dead na po yung mga links :(
sino po may copy ng source code nito..
need lang po para sa SAD subject namin.. :(
Offline dummy_c
« Reply #539 on: June 28, 2012, 10:19:37 AM »
^ Ito sir buhay pa hanggang ngayon. ;D ;D ;D
Marami pa bugs yan, pero working na yan.  :D
So sorry hindi ako naka reply sa PM mo.
By the way ano yang SAD?
Uploaded with ImageShack.us
Sample App  :
http://rapidshare.com/files/415774598/SendRecivTatto_Vb6.zip
pass: www.electronicslab.ph
