^ Clarification lang, which e-gizmo GSM module are you using? the old BENQ GSM module (not being sold anymore since last year) or the newer SIM340DZ-based GSM/GPRS module?Also, FYI, the SIM340DZ-based GSM/GPRS module is now being replaced by a SIM9000 module as of last week. SIM340 and SIM900 are pin compatible anyways.
I see.. we are using the same GSM module I have interfacing problem with this GSM module before when using PIC16F877A with VDD = +5v. In my experiment, I used 3 different voltage translation circuits for testing.1. Direct connect GSM_TX to MCU_RX and voltage divider circuit for MCU_TX to GSM_RX2. Using NPN transistor fro GSM_TX to MCU_RX and signal diode for MCU_TX to GSM_RX3. Using buffer chipAll configurations i tested with the PC + Hyperterminal and all work fine.Now, when i tested to a PIC16F877A, (1) doesn't work reliably. I run the PIC + GSM module setup with a debugger (eICD2), and i can see 1 or 2 received characters that are wrong, i.e. instead of +CMTI="SM",1 in the buffer i get +CMTh = "SM"&1.I tried (3) and it worked perfectly. I used a HC125 buffer chip and it worked. Pero hirap hanapin ang ganito na IC.So I tried (2) also and it doesn't worked sometimes, with wrong characters received but not as often or as unreliable as (1). In my setup right now (2) worked just fine, but testing it on several GSM modules (10 GSM modules to be precise, during a seminar workshop last week in e-gizmo ) it still not as reliable.
im trying this experiment po pero bakit po sa post na ito direct connected na si GSM_TX sa MCU_RX:http://www.electronicslab.ph/forum/index.php/topic,13813.0.htmland we all know that logic high level is 2.0v above and logic low level is from 0 to 0.8v..
then based sa Input High Voltage parameter D040, pag schmitt trigger = ang minimum na input high voltage is 0.8*Vdd. assuming 5V ang gamit mo, 4V ang minimum input high voltage
ahhhhhhh...salamat po sa experiment ninyo po..so this explains it..sa (2) switching npn lang po ba gawin ko? may 3.3v na zener kaya available? hehe try ko maghanap po pati yun hc125 (3)..
^ yup that (2) circuit i'm recommending to TS. Medyo hirap lang kumuha ng stable na +2.8V
^^ kahit sa hyperterminal ganun rin?
ok lang ba to? direct connection from mcu to gsm... pic16f628a(BOREN_OFF) yung supply galing sa VBat ng sim340DZ module. nung tinest ko po... success sya... you mean po isang psu lang gamit nyo?
