Author Topic: Study of Electirc Fan's Mechanical Charging System  (Read 611 times)
Offline mentamide
« on: August 28, 2010, 08:02:24 PM »
Whats your idea regrading this topic ?
  • Pogi/Ganda Points: 630
Re: Study of Electirc Fan's Mechanical Charging System
« Reply #1 on: August 28, 2010, 10:39:13 PM »
^ ano ang gagamitin? mas inefficient rather than directly charging from the outlet.
Offline bravokilo
  • Pogi/Ganda Points: 104
« Reply #2 on: August 30, 2010, 08:08:49 AM »
@Mentamide, if you still referring to the electric fan running a generator or alternator to charge batteries, ang tawag dyan ay "dynamotor".  Motor ang nagpapaikot ng dynamo. It is used in place of a transformer. For example, a 220V motor is hookd up to a car alternator to charge batteries. The advantage is that the alternator is already built, calibratedand has an AVR and cut off.  But there is efficiency issues.  a transformer with diodesand regultorcan do the same job with less friction problems of the motor which takes up energy. Motors themselves are inefficient, meaning, they do not produce the same energy as the input energy.
BK
Offline mentamide
« Reply #3 on: September 03, 2010, 11:57:30 AM »
ano po mga considerations?
« Reply #4 on: September 03, 2010, 12:19:20 PM »
walang consideration. it's just plain... "it's not worth it, it's crap."
surely it will work(oo gagana talaga yan, makakagawa ka nang device), but not worth it and/or nor feasible.
design kna lang nang advance power management for windmill / solar charger mo.
Offline mentamide
« Reply #5 on: September 03, 2010, 05:14:00 PM »
Yun nga po ang gusto ko eh.....patunayan kung bakit di cya feasible.....para wala nang ibang tao ang gumawa nito
« Reply #6 on: September 08, 2010, 12:50:51 AM »
220V outlet --> electric fan motor - losses due to inefficiency of motor
electric fan --> shaft - losses due to friction
shaft --> alternator shaft - possible losses due to friction
alternator shaft --> rotor/stator - losses due to inefficiency of generation
4 na stages, kahit i-consider natin na 95% efficiency per stage, 81.45% ang final efficiency. posible pang walang gumagamit ng fan kaya useless 'yung energy na napupunta sa pagpapaikot ng elisi.
let's consider a direct charger:
220V outlet --> charger
single stage. kung ma-achieve 'yung 95% efficiency, 95% efficient na kaagad siya. less complicated pa at less messy.
Offline mentamide
« Reply #7 on: September 11, 2010, 09:52:32 PM »
sir...thx a bunch.....^_^...bakit kasi ang dami pa ding tao ang gumagawa nan e^_^
