COUNTER pin will be the output of the Coin Acceptor (still i dont know what is the use of the COIN pin )the NC and NO indicates the default setup of your Coin acceptor.. in NC, the Acceptor is closed, if the Coin is validated it will now open else it will rejected.. while in NO, it will close if the Coin if Rejected..=)about the "60ms, 40ms, 20ms", this is the length/width of the PULSE(output) of the Acceptor... for example.. a 5 peso coin will output 5 pulses.. your acceptor is set to 20ms.. it will output 5 pulses every 20ms.. (you can use Timer0 here if you are going to use an MCU)
mga master need pow sa connection sa coinslot machine...baguhan pa kasi ako, ang out put pala namin ay ekakabit sa dynamo. bawat holoh piso iikot ang dynamo for 4 or 5 sec.ang mga connection sa coin slot ay "12v, ground, counter, coin" at may mga switches for time ata un" 60ms, 40ms, 20ms" at "NC at NO"ask ko lang pow san po ba ekakabit ung counter at coin...gagawa paba ako ng circuit for timer or d na...at para san ung mga swtiches pow...thinx sa totolong..yenox pala ung brand sa coin slot machine..
Yes kailangan mo ng timer para sa 4 or 5sec control ng motor mo. For this bili ka ng Yenox Timer.
No a 5 peso coin or 10 peso coin will output only 1 pulse and 60ms, 40ms and 20ms is the time interval of the pulse. It is 1 pulse/coin and 60ms, 40ms, 20ms is the selection of the pulse width.
if(InsertMoney){ if(COINACCEPTOR){ InputAmount++; BUZZER = 1; delay_ms(50); BUZZER = 0; } if(BILLACCEPTOR){ }}
pwede po ba hingi ng circuit diagram sa timer.....kasi walang stock d2 ng yenox timer...pwede po ba gamitin ang 74192 ic sa timer... thinx pow samga info...more power
thinx pow mga master....
mga master may alam kayo replacement sa 74121 wala kasi d2 stock pow...thinx pow ulit....more power
Usually I hack the circuit by removing the transistor then replacing it with jumper. Yun 5V na ang output
